Old 07-12-2007, 01:35 PM   #9 (permalink)
Dad
Administrator
Dad's Avatar
Originally Posted by ben View Post
Dad,
Great write up
Whose mechanical FP gauge and isolator setup did you originally go with?
I have an autometer like that but the like from the isolator to the guage that contains the antifreeze is stainless braided line. I've never had a lick of trouble. It has remained within 1 lb compared to at the IP. The 1 pound variance is due to the thefact that the gauge is mounted a little higher than the isolator.
Before that I had an electric autometer setup that did not make it 7 miles after putting it in. Also at the time (few years ago) I believe autometer was not recommending their electric FP gauge/isolator setup for diesels. Vibration maybe?
Maybe they have got the issues remedied now. I have seen a few Autometer electric setups go belly up. But again, this was a while back.
Again, nice write up and enjoy staring at your new found info as you are going down the road.
I don't want to start a product bash. Let's just say if the kit you're looking at buying has a plastic tube and compression fittings, you might well run into leaking problems.
High Rider: 98.5 Ram 2500 4x4, 5 Spd, SB 13", A3000 turbo, DDP Stage 3 sticks, studded, 4" TB,, AEM Intake, Gauges, FASS95, S-Chips Tune
Low Rider: '06 Chevy 1/2 Ton, Victory Red, 2/4 Drop, roll pan, sport mirrors, rollin on 20's
Dad is offline   Reply With Quote
