Old 07-10-2007, 09:44 PM   #6 (permalink)
lostnwalmart
lostnwalmart's Avatar
if your mechanicaly inclined you can do the lift pump yourself and it should only be $150 from a normal parts store and if it does end up being the injection pump that you can pick up a rbuilt one for 1200 to 1400$ and depending on the drive i could come help you install it (unless of course you would rather have the liability on a shop which i understand) and irecamend some gauges at least a fuel pressure gauge so you can moniter your psi going into the injection pump which isnt the cheapest thing out there. good luck
2001 4x4, airdog 150, Custom nv4500, 8in cat stack, monster 2VP, custom Valair DD, adraline, custom 6 hole injectors, bigstick cam, p&p head, bd special spearco intercoola
Thanks to Dieselnut, Coaltrain, www.hollandcourtsales.com
lostnwalmart is offline   Reply With Quote
