Originally Posted by ramtd02
you say the workharse performs better than the brute force?? I noticed your filterminder had been pulled down.....shouldnt happen with a new filter!! My bruteforce pulls down the filterminder anytime i do a WOT run, and I am extremely dissapointed with the products!!
It does look good and prefer the dry filter, my oil analysis came back great!! silica/silicates was basically 0.
if only they would flow more air!!
Ram, I would like to point out a couple things.
- The filter minder in these shots was pulled down, but that is because when I took the photos, the truck had not even been started yet and the filter minder was pulled down from my Brute Force intake.
- AEM did a running change of the Brute Force kit because of the filter minder location and the correllation they saw between it's location and it's movement.
- The later design is on serveral higher HP trucks than my little 550hp rig and doesn't budge the filter minder with WOT runs on the rollers or on the street.
You might give AEM a call, verify what I am telling you is true and they may even be able to get you fixed up with the later version of the intake tube and you'll be able to verify my findings yourself. They are great people and believe in the products they produce, if it doesn't make power...they won't produce the parts.
Jesse
Jesse Rohr - MBRP Performance Exhaust
email -
jrohr@mbrp.com
