if you turn your fuel screw on the back of your pump about 2 turns you more than likely wont run away and that should give u a bit some people on here forget how it is and not everyone is worried about bs global warming i worry about it about as much as the next time santa cause guess what those two have in common but that should do you enough to smoke out an intersection or two
1991 w250 non int,pump maxed,35" boggers,5spd swap,hx50,stock sticks,soon dual disc,gov spring, sticks
