I have one... (see the pics). It is awesome! I do have a few complaints about it tho...
The Bad:
* going down a bumpy gravel road, the clamps worked themselves loose and the front section popped open and the strut bracket broke. A simple rivet gun fixed the problem, but still. The body of my truck under the rear window is now chipped
* The clamps cause a lot of damage to the bed rails (paint is chipped off right down to the primer in a spot about the size of a quarter), I have them cinched on there pretty good in order for it to not work itself loose. I am gonna get the box line-x'd so hopefully that will solve some of the problem.
* It does take a bit to get everything dialed in, but once you do, its great!
* Unless you use a DB headache rack, finding a solution can be tricky... I had one custom made.
The Good (always want to end on a good note):
* tougher than a mofo... I like that you can put almost 2K lbs of weight on the HD model... I love the extra storage capacity
* I like that they lock... now once I get my locking tailgate, that back compartment will be a nice safe... that was one thing I really liked about my avalanche... the locking tailbage and secured box...
* The ss looks great when its all clean!
I have gotten many compliments on it and have only seen a few of them around town here... glad to know it's still a custom item up here.
Once you get it fitted properly it works like a charm!
2008 Ram 3500 | 6.7L | 6sp | 4x4 | 4" lift | 35" rubber | 17" wheels | AFE Stage 2 | EGR Unplugged | Just enough juice to keep me in trouble and out of the ditch...
Reason: forgot the pictures
