Old 10-11-2009, 03:12 PM   #5 (permalink)
ant.foste
Originally Posted by inthenorth6.7 View Post
I've had mine for about 2 years. I don't load quads but I have carried large reels of wire etc. (electrician) I have had a bit of a time readjusting the cab end to sit tight enough but not to hard to close. I 've just unclip the stuts and lay the cover down to make adjustments. One other thing is after the first winter, it gets very cold here, especially during swings in temp. the rubber tends to stick, and I would force it up. Then the front rubber came off, I reglued it and am going to try a light bit of grease on the rubber to prevent it from sticking. Other than those I like it very much, it's nice to be able to lock it and not worry about someone cutting it with a knife.
Thanks for the heads up on the sticking. I'll find something to put on the weatherstrip to hopefully keep that from happening.
2009 2500 6.7 68RFE QuadCab Longbed 4x4 SLT Patriot Blue
Carli | BlackMaxx | 5" TBE | DiamondBack
ant.foste is offline   Reply With Quote
