Old 09-16-2009, 08:28 PM   #9 (permalink)
carl48
just open the hood and it is the fourth injector line from the front and it is not from rubbing a hole in the line it causes the line to crack and you can not believe how much fuel the cp3 can pump in a very short time. the new cummins ones are made from different metal this may stop the problem the new ones have a whiter color metal and have a torx screw instead of the 8mm head bolt for the isolator
063500dually4X4qcg56,dynatrac,bd exhaust brake,donaldson m090535muffler,cfm+,winspeed spacer,smartyjr,taylor wings,luberfiner bypass filter,psm cold air,cool hose,tag,air tab's,pdr cam,ddp50hp injectors,htt 62 65 13ss,ss manifold, turbo and manifold blankets
carl48 is offline   Reply With Quote
