Resistors to straight pipe a 2013 - Dodge Cummins Diesel Forum
post #1 of 75 (permalink) Old 11-10-2013, 10:22 PM Thread Starter
justin mccabe's Avatar
Do you guys think if I used 100k resistors to straight pipe my 2013 I would have any problems. Saw a guy on YouTube do this to his 2013. Just want to get your guys thoughts.
1998.5 24valve cummins sold.
2006 Lbz duramax sold
New rig 2013 cummins
justin mccabe is offline
post #2 of 75 (permalink) Old 11-10-2013, 10:30 PM
gunslinger226's Avatar
I think you would be the first to attempt it on here, I don't think the guy on YouTube has his truck is running right though. There has been some post on here and the general consensus here is the def is a must with CPU to run correctly so far.
2013 2500 Mega Cab Laramie Bright white,EFI live tuned by Hardway Perfromance.
2004.5 2500 62/s475 built trans and lots fuel: Sold
gunslinger226 is offline
post #3 of 75 (permalink) Old 11-10-2013, 10:32 PM Thread Starter
I wouldn't be deleting everything, egr and everything under the hood would stay. I just want to straight pipe the truck. I know on the older 6.7's you could just use sims but these new 13's are tricky little suckers.
post #4 of 75 (permalink) Old 11-10-2013, 10:37 PM
Quicktime_GT's Avatar
Interested
'13 black Laramie - PPEI, SB3250, BMF,
'07 black qcsb, 6.7 / G56 [sold]
'03 Turbo Cobra
Quicktime_GT is offline
post #5 of 75 (permalink) Old 11-10-2013, 10:39 PM Thread Starter
Only thing I'm worried about is the def
post #6 of 75 (permalink) Old 11-10-2013, 10:47 PM
kleinbus's Avatar
The ECM reads the pressure difference between DPF inlet and outlet, then SCR pressure etc and someone is going to "fool" the computer with resistors?
In theory if you find resistors that matches the sensor feedback at optimum conditions, meaning no need for DEF or regen, then who knows, it could work...
Following that logic, in theory, you would need X value resistor for DPF inlet side, Y value for outlet side and then something for SCR.
In reality, after working 3 years with Cummins QSB and ISB engines and emission systems, I would not go fiddle any of those emission system and someone claiming they have fooled 2013 DEF system with capacitors is BS as it might run for minute or two, but lets see after 6 months....
2013 Ram 2500 Mega Cab Laramie 4x4 Cummins 3.42
2007 Ram 2500 Mega Cab SLT 4x4 Cummins 3.73
kleinbus is offline
post #7 of 75 (permalink) Old 11-10-2013, 10:51 PM Thread Starter
That's also what I was thinking because these new computers are way smarter than the old ones
post #8 of 75 (permalink) Old 11-10-2013, 11:15 PM
He let it run for 10 seconds....showed nothing on the dash. I call B.S. I had a hard time reading his comments......not sure if he's able to spell.
lizardking is offline
post #9 of 75 (permalink) Old 11-11-2013, 11:03 AM
Gasoline Head
67guzzler's Avatar
Trying to put SIMS on a 2013 and hoping it will work is like someone putting gasoline in a diesel truck and saying the pump looks the same so it should work.
Totally different emissions system from the 2007.5 - 2012 trucks. You have to start from scratch.
-Guzzler
⇩ LINKS TO SOME STUFF ⇩
67guzzler is offline
post #10 of 75 (permalink) Old 11-11-2013, 12:25 PM
sledpuller6.7's Avatar
Can you post a link to the video? I can't find it anywhere.
'09 2500 ccsb 2.6 truck powered by D&J Precision Machine.
'13 3500 cclb dually Laramie Longhorn towrig/dd, 4:10's, Aisin.
RIP Danny Toops, you won't be forgotten.
sledpuller6.7 is offline
post #11 of 75 (permalink) Old 11-11-2013, 12:46 PM
2013 Cummins straight pipe. Pops right up.
post #12 of 75 (permalink) Old 11-11-2013, 01:33 PM
Nope, nothing.
