Replacement air filter 2013 Ram 2500 6.7L - Dodge Cummins Diesel Forum
post #1 of 21 (permalink) Old 10-07-2013, 03:34 PM Thread Starter
Gentlemen...I just purchased a 2013 Ram 2500 6.7L diesel and am trying to find a replacement air filter, K&N, AFE, etc. So far I have had no luck, not even the manufactures reps have been of any assistance. Not looking foe a cold air system just a replacement. Any one have any suggestions or had luck finding a replacement filter?
papajack58 is offline
post #2 of 21 (permalink) Old 10-07-2013, 04:04 PM
The Radio Flyer
gsbrockman's Avatar
iTrader Score: 28 reviews
Really ?????
Air Filters Direct Fit IRF Magnum FLOW PRO 5R OER Air Filter; Dodge Diesel Trucks 03-13 L6-5.9/6.7L (td) 30-80102 - aFe Power Diesel&model=3500&year=2013&engine=6.7L&diesel=tru e&menu=diesel&brandID=60
Air Filters Direct Fit Magnum FLOW PRO 5R OER Air Filter; Dodge Diesel Trucks 03-13 L6-5.9/6.7L (td) 30-10102 - aFe Power Diesel&model=3500&year=2013&engine=6.7L&diesel=tru e&menu=diesel&brandID=59
2014 RAM 3500 Tradesman Crew Cab 4x4 DRW 6.7L Cummins Turbo Diesel 385 hp 850 torque and AISIN 6 speed automatic in Flame Red, Snow Plow Prep Group (Protection Group & 220A Alternator), Popular Equipment Group, Chrome Tubular Side Steps, Chrome Appearance Group, Single Disc CD, LT235/80R17 Bridgestone Duravis R500 HD's, Trailer Brake Control, 3.73 axle ratio, 8.4 Radio w/SIRIUS, ParkSense Park Assist, Parkview Rear Backup Camera, B&W GNKR 1314 Gooseneck Hitch. Purchased new February 20th, 2014. Currently : 211,672 miles and 3,915 hours as of February 16th, 2017. (Average Miles Per Hour = 54.1)
gsbrockman is offline
post #3 of 21 (permalink) Old 10-07-2013, 04:16 PM
Go Packers
camperman's Avatar
Air Filter replacement for K&N
_______________________-
Here are some postings on using a K&N air filter, thought you might find useful.
2012 SLT 3500, CCLB, HO, SRW 4x2, 4.10s, Mineral Grey, Pacbrake air bags, Fumoto oil valve, Cat/Cummins Dual Filter kit, Edge CTS Monitor.
camperman is online now
post #4 of 21 (permalink) Old 10-07-2013, 05:04 PM Thread Starter
Air filter 2013 Ram 2500 Diesel
Originally Posted by gsbrockman View Post
Really ?????
The problem has been that Dodge put a shallow air box in the 2013 and the replacement can only be 4" to 41/2" deep. Will have a look at the flat filter you have suggested. And yes the reps have not been of much help as none could/would give me the physical measurements to check if the filter(s) would git.
post #5 of 21 (permalink) Old 10-07-2013, 05:42 PM
The Radio Flyer
gsbrockman's Avatar
A pic I took of the OEM filter next to a 12 oz. Mountain Dew can. The MD can is 4.75" in height.
post #6 of 21 (permalink) Old 10-07-2013, 06:09 PM Thread Starter
That's the same OEM filter that came with my truck. Now, try to find an after market afe or k&n that will replace it. I can find paper filters (OEM) but not the oiled type. Thanks for the feed back
Update, as I'm writing this got a call from my truck salesman. He says afe has three filters that will work. They are 30-10102 Pro 5, 31-10102 Dry S and 73-10102 Pro 7. The dealership recommends the Dry S filter as they have been having issues with the oiled filters contaminating some of the sensors.
Thanks again for everyones input and help. I'm going to try the Dry S.
post #7 of 21 (permalink) Old 10-07-2013, 08:42 PM
What's wrong with the factory filter? It flows as good as an aftermarket filter, yets filters way better. If you like your warenty and don't want to run the risk of dusting a 15k engine for no gain of any aftermarket filter, then stick with the stock filter. Don't even consider the K&n filter, I am not going to get into all the negatives about them, you can do a search.
2014 2500 Black Appearance Package big horn CTD 4x4.
Thuren suspension, Rigid 30 inch e series, rear air.
MPD106 is offline
post #8 of 21 (permalink) Old 10-08-2013, 12:04 AM
HoustonRider's Avatar
I always thought the oiled filters were a no no on diesels. I've stayed away from them and always used OEM.
Sent from AutoGuide.com App
carli king trailready amp toyo emt maghytec rigid snapon (cause dodge)
HoustonRider is offline
post #9 of 21 (permalink) Old 10-08-2013, 12:17 AM
Does donaldson make a drop in replacement filter for these trucks?
2013 Ram 3500 SRW CC 4x4 Aisin Laramie Longhorn
CKcummins is offline
post #10 of 21 (permalink) Old 10-08-2013, 12:24 AM
The Radio Flyer
gsbrockman's Avatar
Yes.....
https://dynamic.donaldson.com/webc/W...l?item=1261021
But I'd go Fleetguard also :
Search results for: 'af27684'
The Following User Says Thank You to gsbrockman For This Useful Post:
CKcummins (10-08-2013)
post #11 of 21 (permalink) Old 10-08-2013, 12:28 AM
The Radio Flyer
gsbrockman's Avatar
Another multi-brand crossover link :
http://filterspro.com/results.cfm?searchfor=P616743
post #12 of 21 (permalink) Old 10-08-2013, 12:52 AM
I really cant find the micron rating for the donaldson, so it might be worth a call once its new filter time.
Thanks for the info!
