Regeneration question? - Dodge Cummins Diesel Forum
2013+ General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING
post #1 of 10 (permalink) Old 08-18-2013, 12:45 PM Thread Starter
Hello all,
Im new to the forum and I've only had my truck a week or so. I have a question about the regen with the new 2013's. Im fairly familiar with what it is as the firetruck Im acustom to driving requires Urea fluid /Blue DEF as well. According to the manual, the truck will take care of the regen itself when necessary. Normally on a longer higway trip I believe it said? The process may requre a trip of 30 min or more? The detroit diesel in the other truck I drive will allow the operator to "manually" put the truck through the regeneration process and it takes about 20 min.
Does anyone know if the new 2013 6.7 will allow a "manual" regen by me or will it only happen while operating the truck? I know I can increase the idle up to 1100 or even 1500 RMP while the trucks in park by using the cruise control, will this take care of a regen when my "regeneration required" light finally comes on????
Any help on this???
cbowman541 is offline
post #2 of 10 (permalink) Old 08-18-2013, 12:58 PM
Ram3500Dually's Avatar
You should NEVER see the regeneration required light. If you do, you need to change your driving habits. You CANNOT do a manual regen on a Ram
2013 Ram 3500 Dually CTD 6.7/Aisin/4:10 LSD
Previous Rams:
90 CC Dually, 94 RC LB, 95 CC SB, 98 QC Dually, 00 QC Dually, 01 QC Off Road, 03 QC Dually, 05 QC Dually, 08 QC Dually, 10 CC Dually
Ram3500Dually is offline
post #3 of 10 (permalink) Old 08-18-2013, 01:00 PM
NC Hauler's Avatar
Regeneration takes place "automtically"...truck does it when the DPF sensors deem it necessary for a regen...One can't manually make it happen..
2016 Ram 3500DRW/CC/LB/4X4/4:10/Aisin/Longhorn/rear air assist, Peal White
2016 Jayco 4112 flood totaled..looking for another one
USAF Viet Nam Vet
NC Hauler is offline
post #4 of 10 (permalink) Old 08-18-2013, 01:07 PM Thread Starter
Maybe I read it wrong but I thought it said we could get a "regeneration required" message on the screen???? So what your saying is driver it longer and harder huh???
post #5 of 10 (permalink) Old 08-18-2013, 01:13 PM Thread Starter
Not to beat this to death but.... Lets say I'm crusin up the highway and about to get off the exit and I notice the "regeneration in process" light on. Do I need to stay on the highway for another 30-45 min like the manual says or will it continue to regen at an idol once I get off the highway????
post #6 of 10 (permalink) Old 08-18-2013, 01:27 PM
5001craig's Avatar
I'm pretty sure it's like a wet dream--it just happens.
I think if you stop in the middle of a regen it will still do it whenever it needs to. Maybe it will regen sooner as the process was not completed. Maybe it will start the regen process again upon startup. I'm not sure but it is automatic and does not require anything from me other than keeping the tank with enough fuel.
The only thing I've seen regarding a regen is I got a message of the Evic saying something to the effect of Exhaust Regeneration Complete. I just happened to look at the Evic to see it. I believe this is the only regen I've had based on the mileage I had when it was done (it went back up for the rest of the tank to almost the "normal" average mpg).
'13 3500 SRW Limited Mega Aisin
'06 2500 Laramie Mega--Sold at 280K miles
5001craig is offline
post #7 of 10 (permalink) Old 08-18-2013, 01:34 PM
Diesel_Lee's Avatar
These trucks will continue to regen off of the highway.
Lee
13' Outdoorsman 6spd 4x4
Diesel_Lee is offline
post #8 of 10 (permalink) Old 08-18-2013, 01:36 PM
You "could" get that message if you don't use your truck as designed. If you are already on the highway you should never see that message. It is perfectly fine to shut it down while in regen. It will restart the next time you drive.
Previous Rams:
post #9 of 10 (permalink) Old 08-18-2013, 01:55 PM
HoustonRider's Avatar
Same questions on the Ford forums as well. Drive it when u want, if regen starts when u are stopping/shutting it down, no worries. It will figure out when to do it.
Sent from AutoGuide.com App
carli king trailready amp toyo emt maghytec rigid snapon (cause dodge)
HoustonRider is offline
post #10 of 10 (permalink) Old 08-18-2013, 02:10 PM
No issues with mine and I have a short commute. Last week truck started regen every trip over 3 days before I needed to drive it more than 10 miles and it completed. Plan to check the oil when changed to check for fuel in it.
2013 Ram 3500 SRW Big Horn CCSB 68RFE
mj3431 is offline
