2013 2500, TPS and Tranny Issues - Dodge Cummins Diesel Forum
2013+ General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING
post #1 of 25 (permalink) Old 05-22-2013, 02:39 AM Thread Starter
DPeglow's Avatar
I bought my truck the begining of May, and i'm taking it back to the dealership friday for the second time.
Initially it was for 3 reasons.
1. Alignment was off and it pulled to the Right
2. Tire Pressure System was erratic (Varied 5-10#s daily and I've got Nitrogen in the tires)
3. The radio would turn on when you turned the truck off. Well more like your driving with the radio off, pull in the drive way, and turn the key off and the radio came on, then opened the door and it turned back off.
Pick it up that evening and they tell me They fixed the alignment, reset the TPS, and put a service bulletin in at Chrystler for a fix on the radio (said they've never seen anything like it)
On the drive home, alignment is still off. Doesnt pull as bad but still pulls to the right, and when they did the alignment they didnt center the steering wheel because its off center now too.
TPS is still all over the place.
Called back to scehd another appointment, and service writer says the TPS issue should be fixed with the radio issue when Chrystler releases a new 'flash' for the computer. And to bring it back in and they'll do the alignment again.
But now I feel like the tranny is having some issues. Seems like it slips alot before shifting between what I think is 3rd and 4th at about 35MPH and sometimes then slams into 4th gear. Also other times after accelerating to 35-45 MPH and letting off the throttle and then getting back on it theres a 'clunk' from the drivetrain. Its an auto btw.
Anyone else having these issues?
DPeglow is offline
post #2 of 25 (permalink) Old 05-22-2013, 08:05 AM
ranchertx's Avatar
Bet you have a bad belt on a front tire. Try switching sides and see if it pulls to the left.
2014 Ram 3500 DRW 6.7 Cummins Aisin, Laramie 4X4
2001 Ram 2500 Ext Cab 5.9 Cummins SLT 4X4
1993 Dodge Ram 5.9 4X4 Reg Cab
ranchertx is offline
post #3 of 25 (permalink) Old 05-22-2013, 02:11 PM
Time to find a different dealer if they couldn't manage to align it properly.
Lead Head is offline
post #4 of 25 (permalink) Old 05-22-2013, 02:47 PM
On my 2010 2wd the dealer did 3 alignments under wrnty, paid for a set of tires, and still never got it correct.
Tired of wasting my time, I went to firestone and bought a LIFETIME alignment, first time they got it perfect! Amazing how that works some times.
So sorry to hear about your problems, keep good documentation in case you need to lemon law the sucker. Its a machine, and any machine can have problems. Sucks, cause we all love our cummins rams, but nothings perfect.
Good luck
2016 RGLB DRW Rear Air Ride On Order! 2013 RCLB 2WD G56 FOR SALE, Previous trucks 2010 RCLB 2WD G56, 2008 CCSB 6Speed Hemi 4x4, 2007.5 CCLB DRW 4x4, 2003 CCSB 4x4, 2003 RCLB 2WD, 36' Cigarette Offshore.
TOOLMAN is offline
post #5 of 25 (permalink) Old 05-22-2013, 04:02 PM
It could be an alignment machine that is whacked . . .when I was a kid, my folks had Chevy cars, and in 14+ years, could never align one right (but anyone else could). It was so bad once that a new set of tires has cord showing in about 1000 miles . . .
- Tim
2011 2WD 2500 Crew Cab ST w/8' bed, bone stock and staying that way . . .
tadawson is offline
post #6 of 25 (permalink) Old 05-23-2013, 12:46 AM
dgiturbo's Avatar
Originally Posted by DPeglow View Post
I bought my truck the begining of May, and i'm taking it back to the dealership friday for the second time....
But now I feel like the tranny is having some issues. Seems like it slips alot before shifting between what I think is 3rd and 4th at about 35MPH and sometimes then slams into 4th gear. Also other times after accelerating to 35-45 MPH and letting off the throttle and then getting back on it theres a 'clunk' from the drivetrain.....
Yes, that's exactly what mine is doing. It's at the dealer now so will advise what they say the issue is when I pick it up. There is also another forum member having the same issue also. Same vehicle, RAM 2500 diesel.
2013 RAM 2500 Laramie CTD, Crew Cab, 4X4 all options. Added: Cabin Air Filter, LineX Bedliner, Craven Speed Stubby Antenna, Nokian Rotiiva 285/70/17
dgiturbo is offline
post #7 of 25 (permalink) Old 05-23-2013, 12:55 AM
mine has a very similar trans issue here is the email I sent to my service manager
Brad
Are there any know software issues with the tranny shift algorithm? My 2013 2500 hd with the cummins with the 68rfe trans clunks and bangs if you get with it to pull out into traffic and then once up to speed let off as the trans shifts to high gear it clunks and bangs or if you are in traffic and on and off the throttle as traffic slows or picks up the pace it acts as if it dont know what gear to be in and clunks and bangs its way to a gear. I ask because I just traded a 5 yr old duramax with 30k on it that shifts perfect and my new truck feels like its got 200k on it and the trans hasnt been serviced since day one. Not unhappy with the truck just hope this isnt normal
Brett
closs2sx is offline
post #8 of 25 (permalink) Old 05-23-2013, 09:10 AM
Trans issues
I too was wondering about the shifting. It wasn't as smooth as my 11 1500. As this is my first diesel I chalked it up to being how it was supposed to be. It almost feels like the TC is not locking/unlocking at the correct times. Let me know what you find. On my 1500 there was a TC issue that after 3 trips to the dealership they finally swapped. They never actually found an issue but when I brought them a Star Case number they looked it up and said they could swap it under that case. I'll be bringing it to their attention at the next service window unless someone comes up with a known issue that is documented with a case or recall number.
Eric
Manassas, VA
2013 Ram 2500 Laramie Rambox crew Shortbed 4x4 black
estoltz is offline
post #9 of 25 (permalink) Old 05-23-2013, 02:27 PM
My truck (2500 w/ 68RFE) has the same clunking issue, seems to happen if you let off the gas about the same time as it's upshifting to 4th.
I've been driving exclusively in tow/haul mode for the past week, and the tranny doesn't clunk in that mode, so the issue definitely seems to be programming related. Aside from the no clunking, overall driveability of the truck in all speeds/conditions (including empty) seems to be better in tow/haul; shift points are a bit higher keeping the engine from lugging, and the exhaust brake is more effective.
I'd give tow/haul mode a shot until Ram comes up w/ a remedy for the clunking issue. Now I just wish tow/haul would be a "sticky" setting, rather than having to enable it every time the truck is started. Hopefully H&S or another tuner will be able to solve that.
- Chris
'13 Ram 2500 CCSB Laramie 4x4, 6.7L CTD, 68RFE, factory ordered spring 2013
SnugTop Super Sport and Amp Power Steps for now... 3" Carli lift and 37" tires coming soon...
Slyder is offline
post #10 of 25 (permalink) Old 05-23-2013, 02:57 PM
dgiturbo's Avatar
If no resolution from RAM dealer I will try that until an update is released. In the mean time, I found this older TSB info.
"Overview:
This bulletin involves selectively erasing and reprogramming the Transmission Control
Module (TCM) with new software.
Symptom/Condition:
The customer may experience a harsh downshift from the transmission when coming to a
stop. When a vehicle stop is initiated from 4th gear (around 40 Km/h or 25 MPH), the
harsh downshift condition will usually occur as the vehicle decelerates to a speed of about
16 Km/h (10 MPH) . If the transmission is in 2nd, 3rd, 5th, or 6th gear, when the stop is
initiated, the condition will not be present. This may cause the condition to appear to be
intermittent to the customer. Because the harsh downshift may occur below 16 Km/h (10 MPH),
the customer may believe that they are experiencing a harsh 2 - 1 downshift.
Some customers may also experience a harsh 2-3 upshift during normal acceleration.
This symptom is less common than the harsh coastdown shift."
dgiturbo is offline
The Following User Says Thank You to dgiturbo For This Useful Post:
Slyder (05-23-2013)
post #11 of 25 (permalink) Old 05-23-2013, 03:32 PM
frobozz's Avatar
I've also been experiencing some less than perfect shifts, but I'm sure that will improve with time... as I learn to master the G56 ;-)
Duncan
Omaha Orange 2013 2500 Megacab 6.7L G56 4x4
frobozz is offline
The Following User Says Thank You to frobozz For This Useful Post:
DIESELBLOCK (05-27-2013)
post #12 of 25 (permalink) Old 05-23-2013, 03:54 PM
tow hual smoothed mine right out told ram they need to look at parameters or change my tow haul so it comes on when truck is started as i cant drive it like it is it drives me nuts
closs2sx is offline
