Fuel filters for 2013 6.7 - Page 4 - Dodge Cummins Diesel Forum
 6Likes
post #37 of 327 (permalink) Old 06-21-2013, 01:56 PM
Sock Puppet's Avatar
Originally Posted by XFord View Post
You are correct for the old 6.0 and 6.4L Fords but the new 6.7 Fords are very easy to change, filter wrench and one hand. However, they are now susceptible to road hazards. Ram looks like they hit the right mix of protection with ease of access. I don't mind paying $120 for filters if they do their job. Ford filters don't stop water and I'm not waiting for that 15G kick in the nards to find out they won't warranty their mistake.
Agreed. When it comes to water separation, I'm sure there are advantages to having an upper and lower filter. While the frame mounted filter isn't wonderful, I think they did an OK job of striking the balance between protection/access.
Sold: 2014 RAM 2500 MC 4X4 Big Horn CTD, 2013 Ram 3500 CCSB 4X4 CTD, 2005 2500 CCLB CTD, 1990 RCLB CTD.
Sock Puppet is offline
post #38 of 327 (permalink) Old 06-21-2013, 04:15 PM
There's a lot of people with aftermarket filter systems that use the frame rail for mounting their setups also. Unless you do a lot of rock crawling you should be ok, I had an airdog on my 06 quad cab short and it was in a nasty spot, never had any filter dent/rock problems. I did carry an extra set at all times though. I hope "RAM" doesn't pull a Ford and stick the customer with the bill every time a negligible amount of water ends up in the fuel and causes the weak injection systems to malfunction and wipe out everything.
bigpoppa7948 is offline
post #39 of 327 (permalink) Old 06-26-2013, 10:28 AM
Kevpoppapump's Avatar
Has anybody actually purchased the rear underbody (68197867AA FILTER KI-FUEL/WATER SEPARATOR)? I tried to pick one up but apparently they are backordered...shocking
Not good news if this is THE Primary fuel filter.
2013 Ram 2500 CCSB 4x4 6.7 CTD/68RFE Mineral Grey
Kevpoppapump is offline
post #40 of 327 (permalink) Old 06-26-2013, 11:14 AM Thread Starter
frobozz's Avatar
I ordered some from factorymoparparts.com and UPS tells me they are on the vehicle for delivery today, so we'll see! I ordered some of the other fuel filter and some oil filters from Geno's Garage the same day, and those showed up 2 days ago.
Duncan
Omaha Orange 2013 2500 Megacab 6.7L G56 4x4
frobozz is offline
The Following User Says Thank You to frobozz For This Useful Post:
Kevpoppapump (06-26-2013)
post #41 of 327 (permalink) Old 06-26-2013, 11:43 AM
The Radio Flyer
gsbrockman's Avatar
iTrader Score: 28 reviews
See my Post #23...
I've had both of my filters since June 13th in anticipation of potential problems. Shoot me a PM if you want my dealer's name....
2014 RAM 3500 Tradesman Crew Cab 4x4 DRW 6.7L Cummins Turbo Diesel 385 hp 850 torque and AISIN 6 speed automatic in Flame Red, Snow Plow Prep Group (Protection Group & 220A Alternator), Popular Equipment Group, Chrome Tubular Side Steps, Chrome Appearance Group, Single Disc CD, LT235/80R17 Bridgestone Duravis R500 HD's, Trailer Brake Control, 3.73 axle ratio, 8.4 Radio w/SIRIUS, ParkSense Park Assist, Parkview Rear Backup Camera, B&W GNKR 1314 Gooseneck Hitch. Purchased new February 20th, 2014. Currently : 248,664 miles and 4,602 hours as of May 25th, 2017. (Average Miles Per Hour = 54.0)
gsbrockman is offline
The Following User Says Thank You to gsbrockman For This Useful Post:
post #42 of 327 (permalink) Old 06-26-2013, 12:02 PM
TXTad's Avatar
I suppose this is a different filter than the one for the 2012s with the extreme duty fuel filter option?
TXTad is offline
post #43 of 327 (permalink) Old 06-26-2013, 12:15 PM
Duncan
I just ordered 2 from factorymoparparts, so we'll see. If not, I'll have to contact GSbrockman's dealer. Mopar Online Parts was backordered.
post #44 of 327 (permalink) Old 06-26-2013, 05:31 PM
Check engine light problems
I've got a 2011 (2500) and got it in Sept 2011..all was fine until the turbo had a problem in the winter of 2012. The dealer fixed that and since then every few weeks the CEL comes on, and I go back.Once thy ha the truck for almost a week as they had to get some parts. I ended up renting a car, and was pissed about that. Still...the CEL periodically comes on. I was going to turn it into a lemon law complaint(I live in PA.) and I had it back there in May..they put on a 2nd. fuel filter. The charge was 1500 clams. I see that the newer models have 2 fuel filters. Any opinions? I feel that I shouln't have had to pay for that. I bought a new truck , and why should I have to pay for a factory upgrade? Help.
ssivonda is offline
post #45 of 327 (permalink) Old 06-26-2013, 05:54 PM Thread Starter
frobozz's Avatar
Well the filters arrived! Looks just like the pictures earlier in the thread of the one on the truck. Spins on just like an oil filter, and has a giant hole in the bottom where that sensor/valve gets moved from the old filter to the new one. Packaged in with the filter is some sort of o-ring, I assume the one for the bottom fitting. (I'm not going to unwrap the sealed plastic because then the filter is just open on both ends to contamination!)
Duncan
frobozz is offline
post #46 of 327 (permalink) Old 06-26-2013, 07:43 PM
dundonrl's Avatar
Originally Posted by 67guzzler View Post
Is that True? That's pretty cool!!!
So I went to the 2013 Diesel Supplement thinking for sure the Fuel Filter Part Numbers would be there. This is all I could find:
"Fuel Filters We recommend you use MOPARŪ Fuel Filter. Must meet 3 micron rating. Using a fuel filter that does not meet the manufacturers filtration and water separating requirements can severely impact fuel system life and reliability."
HA HA HA HA.
-Guzzler
talking to the guys yesterday at Cummins West, where I bought my fuel filter for 41 dollars, they (Cummins) sells the fuel filters to Dodge/Ram who then adds their dealer markup to them.
FC1(SW) US Navy Retired
2012 Ram 2500 ST CCSB 4x4, G56, 3.73's, Toyo M-55s, Warn 9.5ti multi mount winch and limited slip, with 3487 lbs drawbar capacity. Built Oct 22 2012@0800 engine built Oct 9 2012.
dundonrl is offline
post #47 of 327 (permalink) Old 06-26-2013, 09:21 PM
5001craig's Avatar
So does anyone know the part number for the underhood filter? Is it the Fleetguard FS43255?
Already have the frame mounted 68197867AA on order but want to order a couple sets of both.
Thanks.
Craig
'13 3500 SRW Limited Mega Aisin
'06 2500 Laramie Mega--Sold at 280K miles
5001craig is offline
post #48 of 327 (permalink) Old 06-26-2013, 09:26 PM
The Radio Flyer
gsbrockman's Avatar
Thanks.
Craig
Fuel Filter # 68157291AA
The Following 3 Users Say Thank You to gsbrockman For This Useful Post:
Bigtruck4me (11-17-2013), blackhawk783 (09-02-2013), jackvz (03-12-2014)
