2013 DEF problems - Page 3 - Dodge Cummins Diesel Forum
post #25 of 74 (permalink) Old 05-08-2013, 08:57 PM
mtday's Avatar
Just added DEF for the first time today. Gauge was on the last line before "E". Right around 1900 miles. The gauge, as I discovered, is quite misleading. As another member posted, adding a gallon brought it almost to halfway, and the second gallon to about the three quarter mark. I put two more in (only bought four) and its still not what I'd call topped off. The gauge is over the full line though. Might grab another gallon to see how much more it'll take tomorrow.
So, for those of you watching your needles, it's not linear at all! Lol
2013 2500 - 20" HELO 835 w/ 35 x 12.5 Toyo R/T's - 2" HBS Level - RaceME Ultra - AFE Intake
mtday is offline
post #26 of 74 (permalink) Old 05-09-2013, 12:23 AM
whitenite's Avatar
The level sensor for the DEF tanks are like a RV holding tank level sensor and work in increments so not a linear system like fuel tank sending units.
whitenite is offline
The Following User Says Thank You to whitenite For This Useful Post:
mtday (05-09-2013)
post #27 of 74 (permalink) Old 05-10-2013, 08:21 PM
DODGE4X4's Avatar
I'm at 1,300 miles and my screen says my DEF system needs service and to contact the dealer. Dealer told me just to drive it hard for a bit? Anyone had something similar?
2016, Cummis, 2500, LongHorn, 4x4- AMP Steps, Ranch Hand bumpers, 285/75R18 Toyo MT
2016, 2500 Laramie Power Wagon - AMP Steps, Fab Fours bumpers, 285/75r17 Toyo MT's
2016, Challenger SRT Hellcat, M6
DODGE4X4 is offline
post #28 of 74 (permalink) Old 05-10-2013, 10:36 PM
whitenite's Avatar
Does it say DEF needs service or DPF need service.? Driving it hard will heat up DPF and burn soot, and help that situation, however driving hard has nothing to do with the DEF system operation. Either way with that kind of mileage you should be having zero issues with both systems, you havent driven enough to fill the DPF yet, unless it is not performing an active regen. Nor have you driven enough to contaminate the Nox sensors( in exhaust stream) to give false readings for the DEF (SCR) not scrubbing Nox emissions. I suspect a faulty Nox sensor if it is the DEF message or a faulty pressure sensor if it is a DPF message.
post #29 of 74 (permalink) Old 05-11-2013, 01:43 AM
Ram3500Dually's Avatar
1300 city miles is PLENTY to cause DPF full problems. 300 miles in the city will do it..........
2013 Ram 3500 Dually CTD 6.7/Aisin/4:10 LSD
Previous Rams:
90 CC Dually, 94 RC LB, 95 CC SB, 98 QC Dually, 00 QC Dually, 01 QC Off Road, 03 QC Dually, 05 QC Dually, 08 QC Dually, 10 CC Dually
Ram3500Dually is offline
post #30 of 74 (permalink) Old 05-11-2013, 07:45 AM
ranchertx's Avatar
My truck did a short regen yesterday at 275 miles. It only lasted about ten miles.
2014 Ram 3500 DRW 6.7 Cummins Aisin, Laramie 4X4
2001 Ram 2500 Ext Cab 5.9 Cummins SLT 4X4
1993 Dodge Ram 5.9 4X4 Reg Cab
ranchertx is offline
post #31 of 74 (permalink) Old 05-11-2013, 08:00 AM
DODGE4X4's Avatar
Most of mine is highway but I do idle a few hours a day while I'm on locations but I do turn on my high idle.
DODGE4X4 is offline
post #32 of 74 (permalink) Old 05-11-2013, 08:05 AM
DODGE4X4's Avatar
"Service DEF System, contact dealer"
DODGE4X4 is offline
post #33 of 74 (permalink) Old 05-11-2013, 11:33 AM
whitenite's Avatar
If the truck is not regening properly , yes , DPF can plug as it can accumulate over 46 grams of soot in that period, i am assuming the regen process would be working on a brand new truck. This why i stated it is unlikely a DPF problem already.
I see that it it indeed a DEF issue anyway, so DPF is most likely properly doing an active regen.
post #34 of 74 (permalink) Old 05-11-2013, 11:38 AM
whitenite's Avatar
Odd, the DEF equipped trucks should at least double regen intervals, and regen should be every 500 miles on average. Based on the average regen being 200 -250 miles pre DEF equipment .
Thanks for clarification. Do not let this message go unattended, as your truck will be limited to speed and power after a predetermined amount of miles driven without DEF working properly, and thank the EPA while your at it.
post #35 of 74 (permalink) Old 05-11-2013, 09:45 PM
DODGE4X4's Avatar
I pulled a light load today (7k) for about 4 hours, message has gone away and all seems well.
DODGE4X4 is offline
post #36 of 74 (permalink) Old 05-11-2013, 11:39 PM
whitenite's Avatar
This is a good thing ,as long as the message or CEL is out it won't derate. It will keep a stored fault in mode 6 for further perusal if needed.
