Ram 5500 - Dodge Cummins Diesel Forum
post #1 of 21 (permalink) Old 04-24-2013, 11:30 PM Thread Starter
IRBCTP's Avatar
Ram 5500
I am looking to buy a new 2013 5500. We will be using it to pull a 35ft fifth wheel trailer loaded to about 25k. Is this to much weight? Does anyone have any feedback pulling heavy with these trucks.
Sent from AutoGuide.com App
06 3500 srw q/c s/b 4x4. Stage 1 Afe. Aero 4040xl . Silencer ring and cat mia
IRBCTP is offline
post #2 of 21 (permalink) Old 04-24-2013, 11:43 PM
jack0351's Avatar
The 3500s are rated to tow 30K, so I can't see how a 5500 couldn't do 25K. Double check your numbers (GVW, GCVWR, RAWR) and move on from there.
Jack
2013 Ram 3500 CCLB DRW 6.7/Aisin/4.10s (Stock)
2012 Voltage 3600 Epic package
jack0351 is offline
post #3 of 21 (permalink) Old 04-25-2013, 12:28 AM
Here is a website with tow ratings for Ram 4500/5500.
http://www.rambodybuilder.com/ph2013...5500ccmlup.pdf
2015 White 2500 CC SB Tradesman 4x4 68RFE
wagon_train is offline
post #4 of 21 (permalink) Old 04-25-2013, 12:35 AM
Dae
Dae's Avatar
The new 3500 pickup would probably pull a 25K load easier than a 5500 C&C because the pickup has more power.
Dae is offline
post #5 of 21 (permalink) Old 04-25-2013, 04:51 PM Thread Starter
IRBCTP's Avatar
The 5500 has better gearing which I think might be better. Is there anybody who has experience pulling with one of these compared to a 3500?
IRBCTP is offline
post #6 of 21 (permalink) Old 04-25-2013, 06:52 PM
Company Name
kendall03k's Avatar
The ride of the 5500 will be a lot rougher on the load and tire you out more driving it. I would much rather have the extra power with 3.73s than less with 4.88s. I've driven a 5500 and flat out don't like it.. unless maybe you're driving it loaded 100% of the time.
2014 Ram 2500 4x4 - 5" Turbo Back and EGR Delete with PPEI Tuning - Suncoast Mega JR on Order
*Old Setup* - 4.5" BDS Lift Kit, Upgraded Coils All Around, Fox Shocks Upgrade - 20x10 Fuel Nuts with a -24 Offset
kendall03k is offline
post #7 of 21 (permalink) Old 04-25-2013, 08:36 PM
buuuuuuuuuub's Avatar
ive driven a 2012 5500 bucket truck and that thing rode like a caddy. on the other hand it was extremely gutless. id prolly get a 3500
stock.
buuuuuuuuuub is offline
post #8 of 21 (permalink) Old 04-25-2013, 10:12 PM Thread Starter
IRBCTP's Avatar
It will be loaded 100% of the time. Sometimes not as heavy but other close to max gcw. But I will look into the 3500 as long as its capability is going to be high enough. I don't want a real harsh ride but don't want to be overloading the truck as we currently have a 06 3500 and it feels a little over loaded and gets hot even with chip on tow. Egts ate hitting 1450 at times and 1300 a lot.
IRBCTP is offline
post #9 of 21 (permalink) Old 04-25-2013, 10:16 PM
Gasoline Head
67guzzler's Avatar
I think the 2013 3500's are an attempt to "bridge the gap" between the C&C capabilities and the consumer heavy duty line. I think what they're going for is the best of both worlds... Just my take on what I've seen. I've driven NEITHER.
67guzzler is offline
post #10 of 21 (permalink) Old 04-26-2013, 08:19 AM
Go Packers
camperman's Avatar
I've built 4500 & 5500 series trucks on Ram's build site. Just one thing to keep in mind. If you do get one, make sure it was not built with a programed max speed limit. Some come with a 55 mph, 70 mph max speed. You would just have to build one for yourself to see. If purchased at a dealership, that would be one item of major concern. Our sig. truck tows our sig 5er with no problems at all. The 2013's have a higher tow ratings than the '12s. Happy shopping, and happy RVing.
2012 SLT 3500, CCLB, HO, SRW 4x2, 4.10s, Mineral Grey, Pacbrake air bags, Fumoto oil valve, Cat/Cummins Dual Filter kit, Edge CTS Monitor.
camperman is offline
post #11 of 21 (permalink) Old 04-26-2013, 09:12 AM Thread Starter
IRBCTP's Avatar
It's not for an rv. The trailer is hauling a 11500# bobcat with a screw pile auger and also the piles themselves. The piles can easily add up to another 6 or 7k if there is any amount of them. Just want more truck than we need rather than pushing a 3500 like we are now. But I don't want to be way underpowered and crawling up hills because of the derating.
IRBCTP is offline
post #12 of 21 (permalink) Old 04-26-2013, 09:16 AM
Company Name
kendall03k's Avatar
If you're having to have a chip on the '06.. well the new C&C trucks have the same power as an '06 5.9. The gears help a little, but are not replacement for power.
