5th wheel prep package - Page 39 - Dodge Cummins Diesel Forum
post #457 of 605 (permalink) Old 07-29-2013, 11:16 PM
HWTG's Avatar
Originally Posted by silver_2000_tj View Post
Hello,
I'm currently in the market for a new 2013 3500 SRW megacab 4X4 and wanted to know if the gooseneck / 5th wheel prep package was available on the megacab platform with the 6.4 bed or only on the 8 foot bed. I asked the dealer I stopped at on the way home from work tonight and they were unsure on the answer.
Yes it is, I have it on my 2013 3500 DRW Mega Cab.
2017 Ram 3500 Laramie Mega Cab Dually 4:10 Aisin Rear Air Suspension
2013 KZ Inferno 3710T Toy Hauler
HWTG is offline
post #458 of 605 (permalink) Old 07-30-2013, 10:42 PM
silver_2000_tj's Avatar
Well I found the perfect truck with all the options I'm looking for but the fifth wheel gooseneck prep package. Does anyone know if this can be added at the dealership?
White & Silver 2014 Ram 3500 SRW Megacab 4X4 68RFE auto, 60 Gal RDS fuel cell, running Nitto Terra Grapplers G2's 295/70/18
silver_2000_tj is offline
post #459 of 605 (permalink) Old 07-30-2013, 11:17 PM
No, but you can add a ball and/or rails just like you did in the past. I would NOT let it stop me if that is the truck you want.
04 2500 dually. Cancelled '13 Limited. Newly ordered '14 Longhorn crewcab dually Aisin 3.73 on 7/25/13
Delivered 9/11 Woohoo!
mpierce is offline
post #460 of 605 (permalink) Old 07-30-2013, 11:23 PM
You can get the B&W turnover installed for $600. If that is he only hiccup, I would get the truck.
2013 3500 SRW MEGA 68RFE 4X4
N2O2HE is offline
post #461 of 605 (permalink) Old 07-30-2013, 11:56 PM
It's more of the fifth wheel hook up then the goose neck. I use the fifth wheel hitch to pull the travel trailer a couple weekends out of the month, and would like to have a flat bed in the truck. The current setup have the rails and it would be really nice to get away from them.
post #462 of 605 (permalink) Old 07-31-2013, 07:05 AM Thread Starter
ranchertx's Avatar
BW turnover ball and Anderson or companion hitch!
2014 Ram 3500 DRW 6.7 Cummins Aisin, Laramie 4X4
2001 Ram 2500 Ext Cab 5.9 Cummins SLT 4X4
1993 Dodge Ram 5.9 4X4 Reg Cab
ranchertx is offline
post #463 of 605 (permalink) Old 07-31-2013, 07:38 AM
I have the Pullrite removeable rails. They act essentially the same as the RAM package, except the two rails are separate, instead of one piece. Much lighter that way too. Remove the 4 pins that are 1/4 turn, and remove it all. Bed is now smooth.
But, if I was starting all over, and did not already own a 5th wheel hitch, I would go with the Anderson hitch with a B&W ball. Looks good to me, with good reports on here.
mpierce is offline
post #464 of 605 (permalink) Old 07-31-2013, 10:37 AM Thread Starter
ranchertx's Avatar
Mpierce, that Pullrite system wont work will it? The spacing is wrong and the rails will be too far apart for a fifth wheel hitch wont they?
post #465 of 605 (permalink) Old 07-31-2013, 11:21 AM
That is true for the OEM 2013 factory 5th wheel prep package. However, in post #458, silver posted that he found the perfect truck, but it did NOT have the OEM 5th prep package.
So, without the prep package, you can get the ball mounted, and go with the Anderson. Or, if you want clean bed for 5th, get the Pullrite removeable rails.
Just like pre 2013 trucks.
If I did not have a hitch already, I think I would put in the B&W ball, and then use the Anderson, like you did.
mpierce is offline
post #466 of 605 (permalink) Old 08-02-2013, 01:14 PM
jack0351's Avatar
Well, I finally got to tow with my truck, after having it for more than 3 months!
Thanks to RancherTX, I bought a gooseneck ball and the Andersen hitch, and made the "conversion" to my Voltage (est empty wt 14.5K, and GVW of 19K.) I took it out yesterday for a whopping 15 mile tow (from one campground to the next) and had NO issues. I'm still not completely comfortable with it (just a personal comfort level), but it definately performs! It feels a little different, and is more of a pain to physically hook up. I've not towed with a GN type hitch before, so I had fun lining up the holes, although I did manage to get lined up in less than 5 minutes.
I think the biggest "problems" I had were: 1) how high I had to lift the rig to hook up, and 2) stressing out about the pinbox hitting the sides of the bed in a tight turn. Thankfully, neither concern had any major justification, and the only issues I ran into were due to my towing ability/skills.
Just like ranchertx, I stand ready to answer your questions about this hitch, and my towing experiences with it.
Jack
2013 Ram 3500 CCLB DRW 6.7/Aisin/4.10s (Stock)
2012 Voltage 3600 Epic package
jack0351 is offline
post #467 of 605 (permalink) Old 08-04-2013, 11:44 AM
We just returned from a week-long trip to Montana (from Seattle area), our third and longest tow with the Reese drop in ball and the Andersen Ultimate hitch. The hitch system worked flawlessly. As stated before the hitching process is a bit more cumbersome but using the IBall wireless camera system helps a lot.
I have the "picture frame adaptor" sitting in the box next to my Hijacker Ultraslide hitch out on the patio to do a comparison (some day).
The 3500/SW/Aisin is leaps and bounds over my prior 05 2500 with respect to handling, comfort and power. The engine brake is simply amazing on those mountain passes!
Cheaprocker is offline
post #468 of 605 (permalink) Old 08-08-2013, 03:46 PM
JnS RamCummins's Avatar
just got the call from dealership that my "picture frame" adapter is ready for pick up. Trying to put my pullrite superglide on it. Will let you all know how it goes.
JnS RamCummins is offline
