5th wheel and Gooseneck prep? - Dodge Cummins Diesel Forum
2013+ General Discussion General Chit Chat About the 2013 model year differences 6.7L 4th generation Cummins - NO ADVERTISING
post #1 of 68 (permalink) Old 03-18-2013, 12:58 AM Thread Starter
Does anybody know if this option package comes with the standard tail gate? Saw a U-tube video and it showed a cut down tail gate when showing this package on the truck. Want to make sure I get the standard tail gate. I will need to change my order. Ram need to get there web site up and running. Thanks
nitromax is offline
post #2 of 68 (permalink) Old 03-18-2013, 01:05 AM
Dae
Dae's Avatar
The brochure I have doesn't mention anything about the cutout tail gate.
"13MY Ram 3500 offers a fifth wheel / gooseneck prep option. It includes a factory-installed rear structural cross member and five holes in the bed for fifth wheel (four outer holes) and gooseneck (center hole) hitches. Plastic covers for the holes are provided. Also comes equipped with an additional 7-pin connector mounted inside the box."
Dae is offline
The Following 2 Users Say Thank You to Dae For This Useful Post:
JAXCUMMINS (04-08-2013), TRAVLN2 (05-21-2013)
post #3 of 68 (permalink) Old 03-18-2013, 01:05 AM
Ram3500Dually's Avatar
That tailgate in the video was a one off deal. That is not part of the package. If you look in this section for the video walkaround of the 2013 Ram that truck has the goosneck package and the standard tailgate
2013 Ram 3500 Dually CTD 6.7/Aisin/4:10 LSD
Previous Rams:
90 CC Dually, 94 RC LB, 95 CC SB, 98 QC Dually, 00 QC Dually, 01 QC Off Road, 03 QC Dually, 05 QC Dually, 08 QC Dually, 10 CC Dually
Ram3500Dually is offline
The Following User Says Thank You to Ram3500Dually For This Useful Post:
whitenite (04-08-2013)
post #4 of 68 (permalink) Old 03-18-2013, 06:37 PM Thread Starter
Thanks Guys! Just need to make sure I don't get that funky tail gate. I will leave my order as is.
nitromax is offline
post #5 of 68 (permalink) Old 04-04-2013, 05:24 AM
Is there a configuration or layout dimensions of the holes used in the short-bed? Anything that describes exact locations measured from the rear of the truck bed?
mmcbride56 is offline
post #6 of 68 (permalink) Old 04-06-2013, 01:03 AM
Does anyone know what hitch for sure will fit the new bed pucks ? Have heard they are going to be different spacing than the ford OEM hitch puck spacing ?
Called curt hitch tech line and they said they are not making a hitch right now for the fifth wheel option.
If I make the trade to a 13 3500 I will have to have a fifth wheel hitch fast- don't have time to wait 5-6 months for company to design a hitch for this option
2013 Ram 2500 MegaCab 4X4 6.7 Cummins, Auto Trans
jsdan is offline
The Following User Says Thank You to jsdan For This Useful Post:
sledpuller6.7 (04-06-2013)
post #7 of 68 (permalink) Old 04-07-2013, 07:32 PM
Ynotturbo's Avatar
You will need to order the adapter kit for the fifth wheel prep package. Here are some of the details I received from my dealer. My kit is on order with an arrival date of 25 April. Here is the part number needed to adapt a common fifth wheel hitch to the truck with prep pkg.
Hitches will require an above bed fifth wheel installation kit (Part #: 82213667). It consists of a bracket to adapt from common fifth wheel hitches to production mounting points on the truck and includes the captured quarter turn tie-downs that mate to the under bed mounting brackets. It is a rectangular tube steel frame with multiple mounting points for commonly available fifth wheel hitches with 22” rail spacing. The purpose is to allow the customer to adapt a fifth wheel hitch that they already own to the factory installed fifth wheel / gooseneck prep kit.
2016 Laramie CC Dually w/air bags, 24K CURT Fifth Wheel Hitch. aisin,, 4.10 Gears and 900 lbs. of Grunt....towing 2011 DRV Lexington 43 Bunkhouse...
Navy Chief (Ret.)....
Ynotturbo is offline
The Following 2 Users Say Thank You to Ynotturbo For This Useful Post:
post #8 of 68 (permalink) Old 04-07-2013, 08:22 PM
How much does this adapter kit run ? Any links or pics of this adapter- can't find any info on a general search.
jsdan is offline
post #9 of 68 (permalink) Old 04-08-2013, 01:31 AM
Question
Hitches will require an above bed fifth wheel installation kit (Part #: 82213667). It consists of a bracket to adapt from common fifth wheel hitches to production mounting points on the truck and includes the captured quarter turn tie-downs that mate to the under bed mounting brackets. It is a rectangular tube steel frame with multiple mounting points for commonly available fifth wheel hitches with 22 rail spacing. The purpose is to allow the customer to adapt a fifth wheel hitch that they already own to the factory installed fifth wheel / gooseneck prep kit.
So, given that this is to allow one to "adapt" an existing hitch to the NEW truck, what, on the other hand, is SUPPOSE to fit the PREP package seeing as Dodge is not providing a "factory" hitch assembly complete, like Ford offers!
I would like to know what hitch Dodge recommends as a "stock" for those of us that do not already own a hitch? Seems fitment for the new Dodge Ram with factory prep package does not appear to be on the radar for the most common hitch manufacturer's. I have tried PullRite and Curt, all to no avail.
Surely Dodge RAM had to use someone's spec to fit the hole spacing and alignment???
If at all possible, I would like to order the PullRite SuperGlide 3600 for the short-bed (6'4'' & Mega-Cab). I have contacted PullRite and they have not evaluated fitment for the 2013 RAM trucks yet and will not say if the current SuperRails will work. Because of that issue alone, I may have to go with ordering the Crew-Cab and 8' long-bed and hope that the Reese Elite 25K will fit the hole spacing without the adapter rails mentioned above!
post #10 of 68 (permalink) Old 04-08-2013, 08:26 AM
Banned
it's not Dodge Ram... it's just Ram
JAXCUMMINS is offline
post #11 of 68 (permalink) Old 04-08-2013, 11:11 AM
For goosenecks, do we have simply a Ram ball to drop into place w the hitch package?
blackbrush is offline
post #12 of 68 (permalink) Old 05-06-2013, 08:38 PM
Ynotturbo's Avatar
This is what the dealer sent me.
20,000 Fifth Wheel (Part #: 82213822)
MSRP = $700
Note: Requires MOPAR roller ($200 MSRP) or fixed legs ($175 MSRP)
FIFTH WHEEL / GOOSENECK PREP OPTION
Both of these hitches will require an above bed fifth wheel installation kit (Part #: 82213667). It consists of a bracket to adapt from common fifth wheel hitches to production mounting points on the truck and includes the captured quarter turn tie-downs that mate to the under bed mounting brackets. It is a rectangular tube steel frame with multiple mounting points for commonly available fifth wheel hitches with 22” rail spacing. The purpose is to allow the customer to adapt a fifth wheel hitch that they already own to the factory installed fifth wheel / gooseneck prep kit.
MSRP = $575
25,000 Fifth Wheel w/ Fixed Legs (Part #: 82213821)
MSRP = $1,125
The Following User Says Thank You to Ynotturbo For This Useful Post:
jack0351 (05-06-2013)
