LED Fog Light replacement. - Dodge Cummins Diesel Forum
 3Likes
post #1 of 14 (permalink) Old 06-18-2017, 08:03 AM Thread Starter
Good Morning fellow truckers.
I would like to replace my factory fog lights with some LED lights. Are there drop in bulb replacements that anyone would recommend? How about full bolt on replacements? which is the preferred method of replacement?
Also would like to do some in cab accent lighting. Color changing LED accent lighting.
I will leave you with an artsy picture of Bessie.
2016/3500/Laramie/CC/LWB/4x4/6.7/Aisin/DRW/4.10
jandrso is online now
post #2 of 14 (permalink) Old 06-18-2017, 09:07 AM
what kind of accent lighting are you looking to do? They make flexible color changing led strips that you can get from amazon, ebay, etc. Its fairly easy to install if you are comfortable wiring.
2017 CCSB 6.7 CTD 4x4 offroad - Tradesman
2000 QCSB 5.9 CTD 2WD 47RE 3.55 (Sold)
gnwes is online now
post #3 of 14 (permalink) Old 06-18-2017, 10:01 AM
The Radio Flyer
gsbrockman's Avatar
iTrader Score: 28 reviews
@67guzzler can assist.....
Im on vacation in Myrtle Beach and dont have the bulb numbers handy. He & I run the same bulb number in OEM housings.
2014 RAM 3500 Tradesman Crew Cab 4x4 DRW 6.7L Cummins Turbo Diesel 385 hp 850 torque and AISIN 6 speed automatic in Flame Red, Snow Plow Prep Group (Protection Group & 220A Alternator), Popular Equipment Group, Chrome Tubular Side Steps, Chrome Appearance Group, Single Disc CD, LT235/80R17 Bridgestone Duravis R500 HD's, Trailer Brake Control, 3.73 axle ratio, 8.4 Radio w/SIRIUS, ParkSense Park Assist, Parkview Rear Backup Camera, B&W GNKR 1314 Gooseneck Hitch. Purchased new February 20th, 2014. Currently : 256,019 miles and 4,740 hours as of June 16th, 2017. (Average Miles Per Hour = 54.0)
gsbrockman is offline
post #4 of 14 (permalink) Old 06-18-2017, 10:55 AM
cummins345's Avatar
I bought these for my truck Dodge Ram: XB LED - Fog Lights from Morimoto HID it uses the factory brackets and plug in and play.
DDRamFan likes this.
2014 2500 6.7L 68rfe,2.5" leveling kit, 20x12 Fuels,33x12.50 toyo M/T,,Afe intake,20" lightbar,Efi live HPP 5"tbe
cummins345 is offline
post #5 of 14 (permalink) Old 06-18-2017, 11:19 AM
Originally Posted by cummins345 View Post
I bought these for my truck Dodge Ram: XB LED - Fog Lights from Morimoto HID it uses the factory brakes and plug in and play.
morimoto makes great lights
cummins345 likes this.
gnwes is online now
post #6 of 14 (permalink) Old 06-18-2017, 02:48 PM
JBS4X4's Avatar
I did this to my truck. One light on the factory switch and added an extra switch for the other. LED Fog Light replacement.-imageuploadedbyag-free1497811688.531760.jpg
2015 BLACK CCSB
DAD has a 2014 METALIC CCSB
JBS4X4 is offline
post #7 of 14 (permalink) Old 06-18-2017, 03:02 PM
MountaineerHill's Avatar
Originally Posted by JBS4X4 View Post
I did this to my truck. One light on the factory switch and added an extra switch for the other. Attachment 664594
I had these for awhile and ran all four as my fogs. The Virginia State Troopers didn't like that one too much. I took them out and just run a LED bulb in my factor housings now.
'14 Ram 2500 - 2.5" Carli Suspension with 22x12 American Force Evo's
'02 2500 SOLD - S468/7x.012/Hotrod VP44
MountaineerHill is offline
post #8 of 14 (permalink) Old 06-18-2017, 03:31 PM
usmcknight69's Avatar
JBS, are you able to change the angle of those cubes? Or are they in a fixed position?
usmcknight69 is offline
post #9 of 14 (permalink) Old 06-19-2017, 02:56 PM
67guzzler's Avatar
I can recommend these as plug and play:
Fog Lights (9005 will fit in 9145 socket): https://smile.amazon.com/dp/B07258X97C
Here are a couple eBay Links for the same thing about $10 cheaper:
http://www.ebay.com/itm/222483271715
http://www.ebay.com/itm/252886857175
Fog Capacitors for 2015+ Trucks: https://smile.amazon.com/gp/product/B00J8QNNWY
-Guzzler
If someone is nice enough to post a truck-related pic,
I'm more than happy to click a "Like or Thanks."
67guzzler is offline
post #10 of 14 (permalink) Old 06-19-2017, 07:43 PM Thread Starter
Guzzler,
Thank you f the info. When I go to the link you attached, the lights are described on Amazon as an adjustable high beam led headlight for a Chevrolet. I am assuming they are interchangeable between makes and are in fact the appropriate ones for a fog light on a 2016 Ram 3500??
I like the fact that they are adjustable and have a variety of lampshades.
Also, the capacitors are required? Do they keep the truck from throwing up error codes and idiot lights?
Thanks again!!
post #11 of 14 (permalink) Old 06-19-2017, 08:31 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 13 reviews
I put opt7 in mine and they are nice and bright.
2012 Laramie Longhorn, EFI by Ryan, 5" FloPro, 35x12.5x20 Toyo AT II
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is online now
post #12 of 14 (permalink) Old 06-20-2017, 02:11 PM
67guzzler's Avatar
Guzzler,
Thanks again!!
The descriptions are just for the seller to target a market. 9005 based bulbs work in our fog lights which officially take 9145.
For 2015+ trucks, the capacitors are required. These will appear to work fine without them but if you look at the light through a camera viewfinder (which can view things much faster than the naked eye), you'd see the LED's are actually cutting out for a few milliseconds and then firing back on. It's too fast with the naked eye. The capacitors fix that.
-Guzzler
Rancho Suspension likes this.
