CK4 Spec oil ok to use in a 2017 Cummins? - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By Gixxer340
post #1 of 9 (permalink) Old 06-17-2017, 02:37 PM Thread Starter
Flash1034's Avatar
Just ordered some Valvoline Premium Blue oil and it is now CK4 Spec. Is this oil ok to use on my 2017 Cummins or is the old Spec better?
Thanks,
2017 Ram 3500 MegaCab, SRW, Cummins/Aisin, Sport Appearance Group, Dual Aternators, loaded except for rear air suspension.
Flash1034 is offline
post #2 of 9 (permalink) Old 06-17-2017, 04:42 PM
saxdogg's Avatar
All newer specs include the previous specs within them, so it should be fine. That's all there is before long so we're in the same boat! Pour it in and hammer down.
2015 Ram 2500 CTD 4x4 Auto CCSB - Lone Star Package - Deep Cherry Red
saxdogg is offline
post #3 of 9 (permalink) Old 06-17-2017, 05:02 PM
7492's Avatar
Thanks,
I just got mine, and they aren't calling for the new oil yet, but use what you have.
17 3500 Laramie loaded minus stupid stuff
2011 Durango Hemi Loaded
09 Freightliner M2 33k GVW ISC 360/1050 RFO9210
7492 is offline
post #4 of 9 (permalink) Old 06-17-2017, 09:07 PM
97hb's Avatar
I've read as long as it's ces 20081 or the new spec 20086 you are good to go. I have some ck-4 rt6 in mine right now.
97hb is offline
post #5 of 9 (permalink) Old 06-17-2017, 11:38 PM
Ltngdrvr's Avatar
Been running it now for a while, can tell no difference.
Why I run the truck that I run:
Ltngdrvr is offline
post #6 of 9 (permalink) Old 06-18-2017, 12:22 AM
There was some buzz around the new CK4 spec and how it was inferior to the outgoing CJ4. Have yet to see any proof that it is inferior. It appears that CES 20086 is on all the CK4 and the old 20081 was on the CJ4. Updated and fully backwards compatible.
I have some 10w30 semi synthetic PetroCanada CK4 oil ready for my first change. 20086/CK4.
It appears that this new CK4 spec and Ford were having issues. Apparently the Powerstroke requires a different oil now. Glad I never went that route.
BrianF is offline
post #7 of 9 (permalink) Old 06-18-2017, 01:03 AM Thread Starter
Flash1034's Avatar
That's kinda my concern, if the Ford can't run it, there must be some difference in the oil....
post #8 of 9 (permalink) Old 06-18-2017, 06:10 AM
Gixxer340's Avatar
Here is a video series by Chevron explaining the new standard and the changes for FA-4 and CK-4 oils
PC-11 Explained | Delo
Enjoy
BrianF likes this.
2014 Laramie Crew cab with just about every option
'01.5 silver qcsb 4x4 NV5600, 55 Block, Heated Leather SOLD
Gixxer340 is offline
post #9 of 9 (permalink) Old 06-18-2017, 01:34 PM
I am less concerned about the CK4. Our engines have massive bearing surfaces and have proved to be easy on oil. Even fully emissions compliant and allowing 24k km oil change indexes. The Powerstroke has, from what I read smaller components, smaller bearing surfaces and factory set oil change indexes around that 8-10k km mark. In a modern diesel is that the best they can do?
BrianF is offline
