Oil dipstick reading thread???? - Dodge Cummins Diesel Forum
 23Likes
post #1 of 49 (permalink) Old 03-19-2017, 09:49 PM Thread Starter
Wasn't there an oil dipstick reading thread not to long ago?? I have been searching and can't find it. I didn't want to start a whole new thread. Lol took my truck to dealer yesterday and even over night sitting my oil level is reading very top of dip stick. Appears to be a quart or so over full. Seems I read that a lot of guys have this issue and it's nothing to be concerned about. I didn't want to drain a quart out if I didn't have to. Thanks! I'm sure the tech probably just pulled the plug and put it back in when flow slowed down. Then put 12 back in. Should I just drain a quart ? I have a tool I can suck some out. Thanks.
Flitastic is offline
post #2 of 49 (permalink) Old 03-19-2017, 10:36 PM
Ltngdrvr's Avatar
A quart over on 3 gallons, nothing to worry with IMO.
Another benefit of doing your own oil changes, you let it have enough time to drain as much old oil out as possible.
pwr2tow and daMonk like this.
Why I run the truck that I run:
Ltngdrvr is offline
post #3 of 49 (permalink) Old 03-19-2017, 10:48 PM Thread Starter
I know. But when it's free and I don't have to dispose of 12 quarts of oil I was hoping it would be perfect. Good thing is , it's spotless. Not one drip or finger print anywhere. I got my oil and both fuel filters done for free. Thanks
pwr2tow likes this.
post #4 of 49 (permalink) Old 03-19-2017, 11:08 PM
Ltngdrvr's Avatar
Just tell the service writer next time to make sure the tech fills it right.
Also want to make sure they are using a mopar filter and not some cheapo POS.
Ltngdrvr is offline
post #5 of 49 (permalink) Old 03-19-2017, 11:11 PM Thread Starter
Yep! Genuine mopar on there!!! I checked. I get 2 free a year and those have been used so I am on my own until next November lol
post #6 of 49 (permalink) Old 03-19-2017, 11:42 PM
ATC
ATC's Avatar
I run my truck 1-2 quarts over on every oil change. Always have, even with my '06. You'll be fine.
KATOOM likes this.
2016 3500 RCLB Tradesman 4x4 DRW G56
2007 2500 RCLB ST Hemi 4x4 -sold-
2006 3500 QCSB SLT 4x2 SRW G56 -sold-
ATC is offline
post #7 of 49 (permalink) Old 03-19-2017, 11:45 PM
Danderson's Avatar
Mine always reads high with a change and 12 qts.
It's been doing that for 10 years now...
I'm coming up on 6K and the dipstick is right at full mark.
'07 2500 SLT,5.9,Regcab.,G-56,4wd,Northstar TC800 popup 24/7. SBC OKHD. Nitto ExoGrapplers. Dynatrac freespins and bj's. Synergy HD steering. Suspension mutt courtesy of Kore, Carli and Thuren.
Danderson is offline
post #8 of 49 (permalink) Old 03-20-2017, 07:34 AM
CRDIOKC's Avatar
I have read on here you drain and add your 3 Gallons and go
Sent from my iPhone using Tapatalk Pro
CC, SRW, LONG BOX, BRIGHT WHITE LARAMIE B&W 1314 HITCH, TINTED WINDOWS 275/70 R18 ON STOCK RIMS, BD THROTTLE SENSITIVITY BOOST[/SIZE][/COLOR]
CRDIOKC is offline
post #9 of 49 (permalink) Old 03-20-2017, 09:16 AM
The Radio Flyer
gsbrockman's Avatar
iTrader Score: 28 reviews
With over a 1.5 hour drain or so on a HOT engine (coolant to operating temps and oil temps around 205*F), and after adding 3 full gallons, mine always appears about 1/8" above the checkered area of the dipstick.
I'm guessing your tech is installing the full 12 quarts...but not draining for the minimum :30 minutes.
2014 RAM 3500 Tradesman Crew Cab 4x4 DRW 6.7L Cummins Turbo Diesel 385 hp 850 torque and AISIN 6 speed automatic in Flame Red, Snow Plow Prep Group (Protection Group & 220A Alternator), Popular Equipment Group, Chrome Tubular Side Steps, Chrome Appearance Group, Single Disc CD, LT235/80R17 Bridgestone Duravis R500 HD's, Trailer Brake Control, 3.73 axle ratio, 8.4 Radio w/SIRIUS, ParkSense Park Assist, Parkview Rear Backup Camera, B&W GNKR 1314 Gooseneck Hitch. Purchased new February 20th, 2014. Currently : 256,019 miles and 4,740 hours as of June 16th, 2017. (Average Miles Per Hour = 54.0)
gsbrockman is offline
post #10 of 49 (permalink) Old 03-20-2017, 10:34 AM Thread Starter
My oil level is at the TOP of the plastic. Not over onto the wire, but the TOP of that plastic part. Way above the hash... First time they changed it , it was half way from hash to the very end. THis time, all the way up. I am certain they just pulled the plug, let most out and just plugged it back up and put 3 gallons in it... I was going to pump out a quart from the dip stick tube but my pump is not really user friendly ( Amsoil sample pump).
2016 3500 SLT DRW, Aisin, 410, Bright white
Pulling 2017 Sundowner 3 Horse LQ horse trailer.
Competitive Rodeo Athlete
post #11 of 49 (permalink) Old 03-20-2017, 10:40 AM
The Radio Flyer
gsbrockman's Avatar
I'd personally be uncomfortable with it at the level you describe.
post #12 of 49 (permalink) Old 03-20-2017, 10:52 AM Thread Starter
I will probably just drain a quart out of it when I get home. Easy peasy.
