To leave def full or empty??? - Dodge Cummins Diesel Forum
 6Likes
post #1 of 17 (permalink) Old 03-19-2017, 08:44 PM Thread Starter
bccumminstimmy's Avatar
So I'm doing my deletes and I'm wondering if I should leave the def tank full or drain it incace I wana put it back to stock one day and I don't wana have problems if the def went bad or something??
bccumminstimmy is offline
post #2 of 17 (permalink) Old 03-19-2017, 08:49 PM
Ltngdrvr's Avatar
Definitely drain it.
The DEF will evaporate eventually and the tank will be full of dried up crusty white powder.
sargenthp likes this.
Why I run the truck that I run:
Ltngdrvr is offline
post #3 of 17 (permalink) Old 03-19-2017, 08:50 PM Thread Starter
Ok thanks I was wondering about that cuz when I spill some it turns crusty
The Following User Says Thank You to bccumminstimmy For This Useful Post:
Jhenderson (03-21-2017)
post #4 of 17 (permalink) Old 03-19-2017, 08:52 PM Thread Starter
I ges it's probably a good idea to blow out the line from tank to exhast to?
post #5 of 17 (permalink) Old 03-19-2017, 09:26 PM
Jared Herzog's Avatar
Rinse it with distilled water also.
Ram 14 2500 RIP 14,700 Stock. 68RFE."The Lemon"
Ram 15 3500 Dually. Stock. Aisin. N Fab wheel to wheel. Weather Tech Mats. Big D Steering Box Brace.
Jared Herzog is offline
post #6 of 17 (permalink) Old 03-19-2017, 09:37 PM
roadrunner197069's Avatar
I'll probably fill mine with something so when the dot looks at the gauges it don't tip them off that I'm deleted. And they do look at the gauges often.
Sent from my SM-N910V using Tapatalk
roadrunner197069 is offline
post #7 of 17 (permalink) Old 03-19-2017, 09:38 PM
Ltngdrvr's Avatar
If you ever want to use it again.
Ltngdrvr is offline
post #8 of 17 (permalink) Old 03-19-2017, 09:42 PM
I thought the tuners could set it to read full? Or anything in between?
post #9 of 17 (permalink) Old 03-19-2017, 10:25 PM
If so that would be great never heard that before. I assumed it had some sort of float that showed fuel lvl. I don't think it is a digital gage so not sure how they could set it with a tune. Definitely worth looking into.
post #10 of 17 (permalink) Old 03-19-2017, 11:37 PM
If i remember correctly one of the tuners using efi live could do it. The information was in one of the very long deleting threads. Hopefully someone else chimes in with more information on the deal. I know i would rather stare at a full gauge. There is no float sensor and it is not linear.
roadrunner197069 likes this.
post #11 of 17 (permalink) Old 03-20-2017, 08:26 AM
Mine reads empty after tuning. I think most of them read empty after tuning. And not because the tanks empty, the tunes set it to empty
Radride and roadrunner197069 like this.
2015 2500 Laramie ccsb CTD, Lots of thuren goodies, fox shox, bmf novakanes, amp steps, lost a few parts underneath, and the list goes on......
Mmecsics is offline
post #12 of 17 (permalink) Old 03-20-2017, 01:25 PM
AKTundra's Avatar
I pulled my egr valves and cooler put the egr kit in, then went to pull exhaust. Taking the DEF Tank bracket off makes pulling exhaust easier. Ended up taking whole def system out. really wasn't that hard. of course I saved everything so I could put it back to stock if I needed, but that's just crazy talk. Poured out fluid, gave it to a friend that is running stock. Point is take the tank and the hoses out. more ground clearance less weight and more room under vehicle. After all said and done I think I lost about 220 - 250 lbs off the truck.
AKTundra is offline
