4.10 Yukons Installed - chatter vibration from stop. - Dodge Cummins Diesel Forum
 2Likes
post #1 of 14 (permalink) Old 03-18-2017, 11:34 PM Thread Starter
jbt1125's Avatar
Just put in 4.10 gears from Yukon. Following 500 mile break in procedure. Taking it easy. Underway the gears feel good. But from a dead stop, especially if cold, I feel a vibration that I would describe as chattering/stuttering. It only lasts a few seconds from dead stop. After driving and warming up, does it less but still does it. Only from a stop. Forward or reverse. Seems to be coming from rear. Normal for new gears?
2017 3500 CTD/Aisin/ CC/ 4x4 SRW/ black flares/ AEV bumpers/ AEV wheels/ BFG K02/ Carli Backcountry/VisionX/ Titan/AMP/Retrax
jbt1125 is offline
The Following User Says Thank You to jbt1125 For This Useful Post:
ramos209 (03-19-2017)
post #2 of 14 (permalink) Old 03-19-2017, 12:00 AM
krs
krs's Avatar
Who installed the gears? Was the back lash set up for .008" and engagement shimmed/set properly for the pinion? Extremely crucial this was done right or the gears can prematurely fail. I would have a drive line shop look at it that specializes in that. At the most only a couple hours labour and fluid.
drittal likes this.
15 Ram 5500 CC60" SLT AS69RC 4.88, Brutus Deck, Maxilift 330.4, BD PAS, RaceMe Ultra Twister Resonator Stack, S&B, Toyo
14 Ram 3500 CCLBDRW Laramie AS69RC 3.73, Espar, TrailReady Fr FabFours Rr Bumper, Rigid,S&B, BD PAS, RaceMe Ultra Twister Resonator, Fox 2.0, 1-pc DS, Toyo
06 Ram 3500 CCLBDRW Laramie 48re 3.73 Espar, ARB, Kenwood, Miller, BD PAS
14 Ram 3500 CCLBSRW Laramie (which is more like a 3/4 ton than a real 1 ton
) 68rfe 3.42, RaceMe Tuning with Edge CTS w/ pyro, StrPipe, GoodYear
krs is offline
post #3 of 14 (permalink) Old 03-19-2017, 12:07 AM
krs
krs's Avatar
It is also possible that the hub or diff bearings don't have proper adjustment.
krs is offline
post #4 of 14 (permalink) Old 03-19-2017, 12:08 AM
K9Kodi's Avatar
I would assume jbt doesn't know the set up or install specs the install shop worked to get unless he was given a sheet. I would take it back to the shop and let them drive it, it's not normal.
K9Kodi is offline
post #5 of 14 (permalink) Old 03-19-2017, 12:16 AM
Ltngdrvr's Avatar
Doesn't sound to me like a R&P gear issue, sounds like a differential issue.
What gear lube did you use when the gears were swapped?
Why I run the truck that I run:
Ltngdrvr is online now
post #6 of 14 (permalink) Old 03-19-2017, 07:41 AM Thread Starter
jbt1125's Avatar
Thanks for all the advice, I don't know the answers to the questions about measurement and type a oil, etc. The shop is not open on the weekends or I would've gone directly there. Planning to do so Monday morning, just hoping to get a bit of for him advice in the meantime. This information will be very helpful for me when I go back and talk to them, thank you! Keep it coming.
jbt1125 is offline
post #7 of 14 (permalink) Old 03-19-2017, 08:30 AM
Jared Herzog's Avatar
Could the lower gears have made the launch vibration from the two piece shaft more pronounced? All my two piece trucks including my current 15 3500 truck with Aisin have a launch vibe if there is more pedal pressure than the minimum needed to get going. Maybe the lower gears have made that known issue more pronounced.
Ram 14 2500 RIP 14,700 Stock. 68RFE."The Lemon"
Ram 15 3500 Dually. Stock. Aisin. N Fab wheel to wheel. Weather Tech Mats. Big D Steering Box Brace.
Jared Herzog is offline
post #8 of 14 (permalink) Old 03-19-2017, 08:37 AM
Jeepstang's Avatar
sounds more like a driveline angle or U joint issue to me. Also if the pinion yoke is loose or with any play in the pinion bearings can cause this. Why it seems to change as things warm up is one I have not heard of but I am sure there is a reason for it possibly metal parts expanding and fluid thinning out as it warms up
2014 Ram 2500 crew cab limited
Jeepstang is offline
post #9 of 14 (permalink) Old 03-19-2017, 09:05 AM
Lifetime Thread Hijacker
Ontario Trucker's Avatar
Definitely not normal, I have to ask if the front & rear differential gears were replaced with 4:10s
Gerry
2011 white Ram crew cab short box, Viair, train horns, Amp bed step
2010 Sandpiper 345RET, 40ft 5th wheel
Ontario Trucker is offline
post #10 of 14 (permalink) Old 03-19-2017, 09:14 AM Thread Starter
jbt1125's Avatar
Yes, front and rear replaced with 410 yukons
From a standing stop, I can put the truck in drive and not even apply gas. For the first two seconds or so, and the first 10 feet of movement, there is a shutter type vibration eminating from rear. It does not do this underway, and in any other gear. Only from a standing stop. In both first or in reverse.
jbt1125 is offline
post #11 of 14 (permalink) Old 03-19-2017, 09:17 AM
If you are not applying throttle then it rules out my drive shaft theory.
post #12 of 14 (permalink) Old 03-19-2017, 09:19 AM
Sorry to hear this, dont drive it until you get it looked at,
maybe take it to the shop & leave it there til the morning, that sux
Gerry
