cheap gas cap - Dodge Cummins Diesel Forum
 6Likes
post #1 of 22 (permalink) Old 03-18-2017, 11:30 PM Thread Starter
kplawncare's Avatar
cheap gas cap
Found this at home depot today fits great seals tight and only cost me 3.21 $
Venkman likes this.
kplawncare is offline
post #2 of 22 (permalink) Old 03-19-2017, 12:13 AM
K9Kodi's Avatar
I have he same one, works great!
K9Kodi is offline
post #3 of 22 (permalink) Old 03-19-2017, 10:26 AM
Jared Herzog's Avatar
I had that after my fernco cap and before the billet cap. I stopped using it. I got thinking it may over time crack the filler neck. Tightening the wing nut expands the rubber seal. I have no proof or evidence that it may hurt anything. I just noticed over time i had to turn the wing nut more. When i got the billet cap it came with three o rings. I had to get a fourth even larger o ring to seal the cap. I attributed it to having a stretched filler opening. I just did not want to risk cracking it. But, i will say again i have no proof. It was possibly paranoia about nothing. Sort of a solution looking for a problem.
Ram 14 2500 RIP 14,700 Stock. 68RFE."The Lemon"
Ram 15 3500 Dually. Stock. Aisin. N Fab wheel to wheel. Weather Tech Mats. Big D Steering Box Brace.
Jared Herzog is offline
post #4 of 22 (permalink) Old 03-19-2017, 11:00 AM
How long did you use it ? I have had one now for over 2 years on my 2014. I don't tighten it very tight just enough to seal it. Never tried ,but probably could pull it out without undoing it. Have read about the concern of cracking the filler tube, but actually not heard of anyone doing it.
Cummins2014 is offline
post #5 of 22 (permalink) Old 03-19-2017, 11:36 AM
I was planning on going with the oatey cap--but I read the above on another forum too. I picked up both billet caps on Ebay...on the cheap--direct from the guy who makes them out of Idaho.
-MJK- is offline
post #6 of 22 (permalink) Old 03-19-2017, 12:24 PM
7492's Avatar
CAll me stupid.... What's wrong with the OEM cap ?
07 Megacab 3500 4x4 6.7Liter 68RFE 22 MPG highway.
2011 Durango Hemi Loaded
09 Freightliner M2 33k GVW ISC 360/1050 RFO9210
7492 is offline
post #7 of 22 (permalink) Old 03-19-2017, 12:46 PM
cheap gas cap
The first flap would lift the wing nut cap. So i would tighten it enough to stay in place and not be lifted by the spring on the flap. I used this for several months only. The cracks i have seen other members get are possibly from the weight of the high flow pumps. Next time you get fuel you can see where the weight of the nozzle pulls on the green plastic and applies stress even with the standard nozzles.
I used the fernco cap on my 14. On my 15 dually the filler lip the cap sat on is much smaller so did not hold the fernco very well. So went to the wing nut cap then the billet.
In the photo you can see the filler neck is almost flush.
HeavyTwo likes this.
post #8 of 22 (permalink) Old 03-19-2017, 01:27 PM
Not stupid at all...on the newer trucks this is what comes from the factory with the new cap-less design.
-MJK- is offline
post #9 of 22 (permalink) Old 03-19-2017, 03:33 PM
67_CTD's Avatar
Can you provide a link to the one's you purchased?
2014 Ram 2500 Tradesman 4x4 CCSB 6.7L
2017 OR Light 297RLS 5th Wheel, BX1 Gooseneck
1997 Ram 2500 Laramie 4x4 CCLB 5.9L CTD SOLD
67_CTD is online now
post #10 of 22 (permalink) Old 03-19-2017, 03:54 PM
. I picked this up from fleece last week. Has 2 O-rings and a magnet to stick to the door while filling up!
2017 2500 sport crewcab G56. Stock for now
G56Canuck is offline
post #11 of 22 (permalink) Old 03-19-2017, 04:47 PM
HeavyTwo's Avatar
Honestly, anything is better then nothing. The only way I would run it open, is if the truck was always on paved roads.
My concern with the "Pipe Seal" solution is how does the rubber handle diesel? Do you think it may dissolve the rubber? I'm NOT saying it does, it is just a concern of mine.
Other then it looking tacky, it should do the trick.
Personally I went with a billet cap.
HeavyTwo is offline
post #12 of 22 (permalink) Old 03-19-2017, 05:22 PM
7492's Avatar
Yea.... Better THAN nothing I guess.
7492 is offline
