Possible To Add OE Rear Air Ride? - Dodge Cummins Diesel Forum
 5Likes
post #1 of 22 (permalink) Old 02-27-2017, 07:03 PM Thread Starter
Mad Maxx's Avatar
I know about the Kelderman Kit.
But...is it possible to add the OE Rear Air Ride on a Coil Sprung 2500?
Would it be a simple, swap out the Coils for the Bags, run some air lines, and you're set? Or are the mounting brackets / points different?
I ask, because on GM SUV's that are coil sprung in the rear, IT IS possible to simply swap the Spring with the Bag, and you're good to go.
DslPwr768 likes this.
'17 Ram 2500 Laramie Cummins
'16 Unlimited Rubicon
Mad Maxx is offline
post #2 of 22 (permalink) Old 02-27-2017, 09:39 PM
cumminsbama's Avatar
I would imagine you can, all mounting spots are there! Now the cost may be prohibitive, look at Total Load Control with the wireless one air compressor. I had it on my 1500 and was great and when I went to the 2500 I put it on this one too! You can set I believe 3 or 4 programmed pressures in the remote so if you have different trailers. All you have to do is install where the bump stops are mount compressor, run the air lines and power to fuse box and your set! I added an additional switch for power to the system. Should be able to get the whole set up on sale for less than $600.
cumminsbama is offline
post #3 of 22 (permalink) Old 02-28-2017, 05:09 PM
Ltngdrvr's Avatar
Anything is possible, but the oem rear air suspension is totally integrated into the trucks body module system. The bags themselves are probably a fairly easy changeover, but the self levelling valves and the compressor system is another story, that part would take some doing and would cost an arm and a leg.
Why I run the truck that I run:
Ltngdrvr is offline
post #4 of 22 (permalink) Old 03-01-2017, 09:18 AM Thread Starter
Mad Maxx's Avatar
I know it's integrated. I'm not doing a full install. Just the Bags and I'll run my own Air Lines.
Mad Maxx is offline
post #5 of 22 (permalink) Old 03-01-2017, 09:24 AM
Ltngdrvr's Avatar
Much cheaper to go aftermarket.
mannblack and Boostosaurus like this.
Ltngdrvr is offline
post #6 of 22 (permalink) Old 03-01-2017, 09:52 AM
TxLaramie's Avatar
Your better off forgetting about oem bags and just get a set of aftermarket like firestone and be done with it.Aftermarket comes in a complete kit whereas oem bags is all you get then you will have to buy all the install hardware.
'16 Laramie Longhorn 3500 DRW/CC/LB/3:73/Aisin/11.8 Rearend
Auxiliary switches-I/P Mounted/5th Wheel Towing Prep
60 gal. Aux tank w/toolbox B@W RVK3600 5th wheel hitch
TxLaramie is offline
post #7 of 22 (permalink) Old 03-01-2017, 09:36 PM
K9Kodi's Avatar
I assume your not wanting air assist, you want full air? Then factory with your own air support would be fairly easy. I'd just be weary of full air if something blew. I'd run air assist
K9Kodi is online now
post #8 of 22 (permalink) Old 03-02-2017, 09:49 AM Thread Starter
Mad Maxx's Avatar
Correct! I want to REMOVE and REPLACE the OE Coils with the OE Air Bags. NOT run a supplemental Air Bag like Firestone, AirLift, Pac Brake, ect...
I'm just trying to find out, if I pull the Coils, if the OE Bags will fit / bolt right in, or is there going to be some modding going on.
Mad Maxx is offline
post #9 of 22 (permalink) Old 03-02-2017, 10:35 AM
Ltngdrvr's Avatar
Guess I don't understand then what the big deal is about the factory airbags?
Aftermarket bags will work just as well for what you are looking to do and would be cheaper.
I haven't seen or heard about anyone replacing the coils with factory airbags, so I doubt anyone is going to have a definitive answer for you.
Ltngdrvr is offline
The Following User Says Thank You to Ltngdrvr For This Useful Post:
ramos209 (03-02-2017)
post #10 of 22 (permalink) Old 03-02-2017, 11:32 AM
67_CTD's Avatar
Nope, they won't.
Some here thought 2WD springs, is all that would be needed to get 2WD ride height on a 4WD truck. I tried it and there are other differences, because it didn't change the ride height.
Wouldn't be surprised to find there are for the factory airbags as well.
2014 Ram 2500 Tradesman 4x4 CCSB 6.7L
2017 OR Light 297RLS 5th Wheel, BX1 Gooseneck
1997 Ram 2500 Laramie 4x4 CCLB 5.9L CTD SOLD
67_CTD is offline
post #11 of 22 (permalink) Old 03-02-2017, 01:49 PM
Again I wouldn't see any reason they wouldn't fit, they don't make special frames and axles for this set up. Why do you want the OE bags? Preference or for a certain reason? The cost vs the supplemental would be way higher. There are air kits for the front and back that allow you to lift truck in demand and lower for garage parking but then Have the lifted look. I guess you just want the integrated OE back look and fit. I would take my 9" Goodyear bags from TLC over any others out there!
post #12 of 22 (permalink) Old 03-02-2017, 05:08 PM
kcollins11's Avatar
I am wanting to swap from coils to air also, please keep this updated with what you do. I have been looking at these.
https://kelderman.com/shop/2014-ram-...il-replacement
-09 Dodge 2500 Quad Cab SWB 4wd DIY race pipe, DIY CCV reroute, No intake baffles, No silencer ring, CSP5 tuning by Pela Motorsports.-98 Dodge 2500 Reg Cab 4wd No fuel plate, Minor pump adjustments, Plugged wastegate, No silencer ring.
kcollins11 is offline
