2016 with random stalling? - Dodge Cummins Diesel Forum
 16Likes
post #1 of 67 (permalink) Old 02-03-2017, 06:38 PM Thread Starter
Partzsf's Avatar
Question 2016 with random stalling?
New member, driven here in search of some wisdom.
I have my truck at the dealer for a random stalling issue and so far nothing..
1. 15k miles on it
2. All but once it has happened while stopped at a light, the other time I was under 5mph coming to a stop.
3. Usually before it happens it will "stumble" at idle.
4. Usually it will happen after exiting the freeway and stopping at a light on the access road, after coming to a stop and sitting at idle for a minute it will stumble and then die shortly afterwards, no codes, no lights, I put it in neutral and it starts back up no problem.
5. This is completely random but I have noticed it happens after sitting overnight or at work all day.
6. If it does happen it will usually repeat the stall within a few minutes, always at the stop. I break slowly no sudden braking stuff and drive conservatively (no hot Rodding).
7. 2016 2500 MegaCab Laramie 4x4
Ideas?
Partzsf is offline
post #2 of 67 (permalink) Old 02-03-2017, 09:06 PM
roadrunner197069's Avatar
My 2016 3500 recently done this 2x. Once on a freeway in houston, once in a parking lot. Not sure why either. Both times on a pretty fresh air filter. I was thinking maybe my keys are to heavy, plus i had a broken ecm fuse I thought maybe was getting dirty or moisture in it. I did change the fuse and so far no more issue, crossing fingers.
Sent from my SM-N910V using Tapatalk
Partzsf likes this.
roadrunner197069 is offline
post #3 of 67 (permalink) Old 02-03-2017, 09:25 PM
terb's Avatar
Remove the cover off your fuse box and make sure they are all pushed in all the way...there is also a wiring connector near where the steering column goes thru the firewall that has been known to not be plugged in all the way .....Has the dealer tried to fix it for you yet?
Partzsf likes this.
2016 2500 Crew Cab Laramie 3.42 Auto
2014 2500 Crew Cab Laramie 3.42 Auto
2008 3500 SWR Quad Cab Laramie 4.10 Auto 5.7 Hemi "Whoops My Bad"
2006 2500 Quad Cab Big Horn 3.73 Auto..
2006 2500 Quad Cab Sport 3.73 Auto..
1998 2500 Club Cab Laramie 12V 3.55 Auto
terb is offline
The Following User Says Thank You to terb For This Useful Post:
Partzsf (02-03-2017)
post #4 of 67 (permalink) Old 02-03-2017, 10:55 PM Thread Starter
Partzsf's Avatar
I'm keyless so no issues with them being loose in the ignition. The dealer look and at it today and couldn't duplicate it, but said there was a know issues with trans fluid being a little low that has caused some random issues such as this. I did some internet searching and there is some info backing this theory up. They were upfront with me and said this was their best guess and I will monitor and see if I happens again, I will update this thread in a week and update everyone and let you know if it persists or has been corrected as it would happen weekly but also randomly.
Partzsf is offline
post #5 of 67 (permalink) Old 02-03-2017, 11:06 PM
My first one happened just before my 60,000 mile transmission service. Second one was after the service.
Partzsf likes this.
The Following User Says Thank You to roadrunner197069 For This Useful Post:
Partzsf (02-05-2017)
post #6 of 67 (permalink) Old 02-03-2017, 11:58 PM Thread Starter
Partzsf's Avatar
I will check them in a week to see if the tranny thing fixed it, I'm trying to be methodical to make sure this is fixed/gone.
Partzsf is offline
post #7 of 67 (permalink) Old 02-10-2017, 11:06 AM Thread Starter
Partzsf's Avatar
As promised a week later update. To date since the dealer worked on the truck it has not repeated the stalling issue.
Partzsf is offline
post #8 of 67 (permalink) Old 02-20-2017, 06:25 PM Thread Starter
Partzsf's Avatar
Exclamation I spoke too soon
So after it doing it 6 times in one day I took I back in and they were able to get it to repeat it for them. Now the good new is they have determined the air intake valve was sticking and have replaced it. So once again I will follow up in a week to see if it is gone for good, on a side note they fixed the wind sounds from the AC air box
Partzsf is offline
post #9 of 67 (permalink) Old 03-18-2017, 02:33 AM Thread Starter
Partzsf's Avatar
Okay so......... it did it again.... wth? Anyone have any ideas I can point the dealership in?
Partzsf is offline
post #10 of 67 (permalink) Old 03-20-2017, 07:14 AM
document each time it does it, and take it to the dealer. sounds electrical to me
2011 CCLB 3500, G56, 4'' TBE, Sinister EGR delete, EFI Live by Anarchy
kawakx125 is offline
The Following User Says Thank You to kawakx125 For This Useful Post:
Partzsf (04-04-2017)
post #11 of 67 (permalink) Old 03-20-2017, 10:24 AM
K9Kodi's Avatar
Are there any codes or lights. Does it do it on its own or only if you give give normal fuel. Like if you baby the throttle will it do it?
K9Kodi is online now
The Following User Says Thank You to K9Kodi For This Useful Post:
post #12 of 67 (permalink) Old 03-20-2017, 12:11 PM
Lins's Avatar
I had similar issues on my '02 Ram 1500 and it was tranny related. Sometimes the fiters let air into the system and the engine is chasing the transmission load as air goes through the system before it's purged. Always happened after the first or second stops after leaving the driveway. If you can duplicate it safely, pull the trans dipstick and see if there are excessive bubbles on it.
2017 6.7L Ram 2500 Laramie Crew Cab Granite Crystal w/ Sport Appearance Group, rear air suspension
Lins is offline
