Best bug remover to clean grille? - Dodge Cummins Diesel Forum
2010-2012 General Discussion General Chit Chat About the 6.7L 4th generation Cummins - NO ADVERTISING
post #1 of 23 (permalink) Old 05-27-2012, 08:17 AM Thread Starter
2LO4ME's Avatar
I swear now that I lifted my dually it gets a ton of more dead bugs stuck to the grille.
Who makes the best bug remover/cleaner?
And whats the most aggressive but safest sponge or cleaning pad to use? I'm assuming a kitchen type scouring pad will scuff the paint. Maybe one of those Dobie pads?
I have a color matched grille, if that matters.
Thanks in advance!
2010 Dodge Ram 3500 reg cab long bed DUALLY. 6" Pure Performance suspension, Pure adjustable track bar, Bilstein 5100s, Hell Bent stering brace, Carli low mount stabilizer, 35x10.5x17 SSRs, Fred's 2" spacers, color matched front.
2LO4ME is offline
post #2 of 23 (permalink) Old 05-27-2012, 08:47 AM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 13 reviews
Windex with ammonia works good.
2012 Laramie Longhorn, EFI by Ryan, Thuren, Carli
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is online now
post #3 of 23 (permalink) Old 05-27-2012, 08:55 AM
dieselpoweredram's Avatar
Try Chemical Guys Bug and Tar remover. I got it and all you need to do is blot some of it on a rag and just rub the bugs right off.
2011 ram 2500 Mega Cab 4x4, Mineral Grey, Larami, Front windows tinted / Weather Tech side window visors and mats / DELETED! 5in TBE, H&S tuned, S&B intake, H&S EGR delete / 20x10 Eagle Alloy 064 series on Nitto Terra Grapplers
dieselpoweredram is offline
post #4 of 23 (permalink) Old 05-27-2012, 09:34 AM
Speciulboy's Avatar
Where do you snag this stuff? Wally world?
Sent from my Autoguide iPhone app
2010 2500CC 68RFE 4x4 "reliable edition" 6 inch Carli radius arm BMF SOTA 20x9 Toyo RT 37x12.50x20 Carli Low Mount Stabilizer Backwoods Bumpers Front and Rear Deluxe Baja Bumpers Rigid Industries 40" LED Lightbar Warn 16.5 Ti
Speciulboy is offline
post #5 of 23 (permalink) Old 05-27-2012, 10:36 AM
I get it online at Auto Geek. Its called bugger heavy duty shampoo. It stinks you can only get it online but it is worth it.
post #6 of 23 (permalink) Old 05-27-2012, 11:11 AM
oldelmer1's Avatar
Try a Bounce dryer sheet, wet it first and watch the bugs rub off. Most of us campers use this and it works very well.
2016 Delmonico red/silver Dodge 3500 Laramie 4x4 Dually CC 8' bed, 3.73, Asian trans. KSH Tool Box/Fuel Tank Combo
oldelmer1 is offline
The Following 4 Users Say Thank You to oldelmer1 For This Useful Post:
6.7L RCLB (05-27-2012), 98whitelightnin (05-27-2012), Delmar (05-28-2012), u-joint (05-27-2012)
post #7 of 23 (permalink) Old 05-27-2012, 11:28 AM
I'll have to give the dryer sheet thing a try. What I usually do is this:
Wait for a day where it's raining and your truck (and grille) has been wet for hours. The bugs come off SOOOO MUCH EASIER when they've been 'pre-soaked' all day with water as opposed to dried and hardened like epoxy ; ).
I use one of those scrubbing bristly dish pan things from the sink (don't tell my wife). The bugs come right off and I don't have to put ANY chemicals on my color-matched painted grille. I might use a little bit of soap from time to time (car wash soap).
2011 Outdoorsman, Crew Cab Short Bed, Auto, 3.73's, White / Mineral Gray, Iron Cross Black Nerf Bars, Retro Solutions 55W low beam HID kit, Toyo Open Country AT II 285/75/17
DieselVirgin is offline
The Following User Says Thank You to DieselVirgin For This Useful Post:
post #8 of 23 (permalink) Old 05-27-2012, 12:48 PM
Toyota and Cummins Nut!
toyota_mdt_tech's Avatar
Thanks in advance!
I use Turtle Wax bug and tar remover. It comes in a spray bottle, gets pitch off too and doesnt strip wax. Just got a bottle a few nights back, found a bunch of pitch drops on my roof and hood after a trip to my remove cabin.
2010 Dodge 2500 SLT Crew Cab Long Bed 4WD G56 6SPD Cummins 6.7 turbo diesel, 3.42 LSD. Add ons: Laramie Alloys, "Powerwagon" flares, Powerwagon bed decal (4X4 off road) OE Ram mudflaps, OE Slush Mats, OE Clearance Lamps, Geno's shift knob in black, spray in bedliner, OE brake controller, Pro Tech Toolbox, Licensed "Extra" class HAM operator, Ranger RCI-2950 10-11-12 meter all mode ham radio/CB, co-phased 4 foot Firestick Firefly 5/8 wave antennas. Yaesu FT7800 2m/70cm VHF/UHF-FM Ham Radio, Larsen NMO2/70C mounted dual band VHF/UHF antenna, Alinco DR-06 6 meter VHF FM, Larsen NMO50C 1/4 wave antenna, 150 PSI on board air system, air powered 157 db train horns!
toyota_mdt_tech is offline
post #9 of 23 (permalink) Old 05-27-2012, 01:36 PM
Please tell me your joking!! If you aren't, I'd hate to see your grille in the sunlight. You don't want to use anything abrasive on your paint.
capnp72 is offline
post #10 of 23 (permalink) Old 05-27-2012, 01:37 PM
Air Force Vet
GSM24's Avatar
The Bounce dryer sheets work great. They work best if you use hot water.
2011 3500 LARAMIE LONGHORN CCLB 4X4, 6.7L HO, 3.73 Gears, 68RFE Auto, SRW, Sagebrush
Edge Insight CTS2 Monitor
26-foot Tracer RLS Travel Trailer (7500 lbs GVWR)
2008 Mercedes Diesel GL 320 CDI (my wife's car)
Civil and Structural Engineer
Totally Stock and Love it!
GSM24 is offline
The Following User Says Thank You to GSM24 For This Useful Post:
post #11 of 23 (permalink) Old 05-27-2012, 03:17 PM
6.7L RCLB's Avatar
awesome advice in here
The Midnight Express
2012 Regular Cab Long Bed Cummins
Deleted and Tuned by GAW Diesel Reverse Leveled With 35" Toyo A/T 2's
6.7L RCLB is offline
post #12 of 23 (permalink) Old 05-27-2012, 04:26 PM
I'd be willing to bet he is talking about the plastic looking scrubber brillo pad stuff, not the metal.
