Vibration at idle. Anyone else? - Dodge Cummins Diesel Forum
2010-2012 General Discussion General Chit Chat About the 6.7L 4th generation Cummins - NO ADVERTISING
post #1 of 23 (permalink) Old 12-20-2011, 03:58 PM Thread Starter
I have a 2010 w 6.7 that has just over 10,000 miles on it. On Sunday at the very end of a 2 hour trip, I noticed a slight vibration in the truck. Especially when sitting at idle, you can feel it in the steering wheel. To me it is very noticible as I'm used to driving it. Other than the vibration, the truck seems to run normal. Dodge dealer looked at it and couldnt find the problem. They called tech support, and they had nothing either. I was told that is how the truck operates, and nothing could be done. Of course I told them it has not had this vibration at all until now so that was not an acceptable answer. They said they would explain that to support and let me know what the find out.
Has anyone ever had this problem or heard of it? I have searched online, but havent found anything similar.
Thanks! Dennis
tridennisr is offline
post #2 of 23 (permalink) Old 12-21-2011, 12:28 AM
Do you feel a vibration at all when driving as well?
2012 Dodge 2500 Mega Cab 4X4
zmock8 is offline
post #3 of 23 (permalink) Old 12-21-2011, 06:09 AM
Farm Truck Diesel
I have the same thing in My 2011
2013 Ram 2500 Laramie
Farm Truck Diesel is offline
post #4 of 23 (permalink) Old 12-21-2011, 08:48 AM Thread Starter
You can feel it ever so slightly when driving, but not to bad. It's most notable when sitting at a stop light. In gear or in park is the same. I asked my wife to drive it last night and she asked if it was running rough? Even though it is running normal, the vibration gives you the impression of a rough idle. Earlier I described it as being in the wheel, as you feel it instantly when holding the wheel, but it is in the enire truck. Seats, floor, you feel it everywhere. Not horrible, but irritating, especially considering it's a new vehicle and not a worn out farm truck. I'm wondering if there is possibly a broken motor or trans mount? It just feels like whatever should be dampening the engine vibration in the cab is not working. I opened the hood, and don't see any engine movement though. And the truck has never done any hard duty to cause motor mount damage. It's hardest day is pulling my 8K camper.
I decided to pick it up from the dealer last night and just drive it a few days and see if it gets worse. The service ticket said " Found no vibration, unable to duplicate." So the dealer doesnt even acknowledge the problem. I'm thinking about going to the sales side and get the keys to a new truck and do a side by side test and see if someone will be able to recognize what I'm talking about. I completely get this is a big diesel truck, however the first 10k miles where fine. This vibration developed recently, and there is no possible way I would have driven the past 10k without noticing it before.
Thanks! Dennis
post #5 of 23 (permalink) Old 12-21-2011, 08:49 AM Thread Starter
FTD Have you had it looked at?
post #6 of 23 (permalink) Old 12-21-2011, 09:15 PM
come on this is normal. while idling my steering wheel shakes for sure. while moving i feel nothing. ithink your justbeing overly paranoid.
2010 3500 Laramie Mega Cab 4x4
ngr2001 is offline
post #7 of 23 (permalink) Old 12-23-2011, 02:07 PM
I just recently experienced something similar. I went to leave work and had the truck idle roughly, very noticably. Even while driving slowly through parking lot. Got home and it was still rough at idle. Check DTC thru MM and found these to codes
P020B - fuel Inj. 2 Performance
P0692 - fan 1 control Circuit High
Cleared them and no more sign of it since Tuesday.
Currently have 15k.
small_toys is offline
The Following User Says Thank You to small_toys For This Useful Post:
FULLBLOWN03 (03-03-2015)
post #8 of 23 (permalink) Old 12-23-2011, 10:38 PM
347strokin's Avatar
I've got 38,000 kms on my 2010 and it's had a rougher idle the last 10,000 kms. It's a touch more noticeable when I fast idle the truck. It's a weird vibration. It doesn't quite line up with the motor rpms. Seems a bit more intermittent. It's so minor though, it seems normal to me now.
2010 Monotone Mineral Grey 2500 Laramie CC 4x4:
4.5, 20's, 35's, dual rear outlet exhaust, Amp Research, tint, subs, LockPick, camera, deletes, trans software.
347strokin is offline
post #9 of 23 (permalink) Old 12-23-2011, 10:40 PM
347strokin's Avatar
Haven't checked for codes yet.
post #10 of 23 (permalink) Old 12-23-2011, 11:05 PM
I have a 2011 3500 4x4 diesel same thing. with 11000 kilometers . vibrates so bad that my loose change in the centre counsell rattles around. hands go numb at 70 kilometers an hour is the worst. on the throddle off the throddle no matter what gear your in, been to the dealer 3 times . dealer has new front drive shaft, new rear drive shaft ,new steadty bearings,new rims and tires and still vibrates.dealer keep changing parts and cant seem to find the problem. i believe that it is the tourge convertor. it vibrates and an idle stopped.
shaky is offline
post #11 of 23 (permalink) Old 12-24-2011, 12:57 AM
With 10000 miles, change the fuel filter, and I think you will see an improvement.
BigR1 is offline
post #12 of 23 (permalink) Old 12-24-2011, 02:13 AM
Back_Water's Avatar
I've also noticed a similar vibration, although slight and intermittent, developed around 10,000-11,000 miles. Mostly at idle and when driving slowly in a parking lot. I've just dismissed it as a vibration in the dash or something. I'm gonna be changing out the fuel filter like ol' dude suggested above, and see what that does. I wanted to change it at my first oil change, but the service manager at my dealership told me that it didn't need changing until around 24,000 miles. Whatever, I've always liked to change fuel filters at every oilchange. Guess I should just stick to my old habits. Thanks guys.
2011 CCSB 2500 6.7L 68RFE 4x4 Laramie/3.73 gears/15% Tint/AMP steps/Cabin Filter Mod/Linex/FabFours/WARN 16.5ti/Bushwacker/Weathertech Liners/PaceEdwards FMJ Bedcover/B&W 9in drop hitch/Nathan Airchime K5LA/Air Zenith dual OB2/dual 5gal tanks/8in BDS longarm/9500 shocks/Carli low mount SS/DSS/37x13.50 Toyo MT on BMF Novakane 20x9 (5in bs/0 offset)
Work harder.... Millions on welfare are depending on you.
Back_Water is offline
The Following User Says Thank You to Back_Water For This Useful Post:
Jwlehman96 (11-22-2014)
