Dully Tire Rotation - Dodge Cummins Diesel Forum
2010-2012 General Discussion General Chit Chat About the 6.7L 4th generation Cummins - NO ADVERTISING
post #1 of 16 (permalink) Old 12-10-2011, 01:12 PM Thread Starter
ram_vs_cougar's Avatar
Dully Tire Rotation
This is my first dully. I have a 2011 Ram 3500 4x4 and I wanted to know how/what is the best way to rotate the tires.
ram_vs_cougar is offline
post #2 of 16 (permalink) Old 12-10-2011, 01:21 PM
whitenite's Avatar
whitenite is offline
post #3 of 16 (permalink) Old 12-10-2011, 02:53 PM
I've heard lately that it is not a good idea to rotate left to right (or vice versa) unless you are having irregular tire wear (i'm not talking about duallys). On;y go front to back...
2014 Ram 2500 Laramie Limited Mega-Cab 4x4 Auto. Granite Crystall Metalic
MattTN23 is offline
post #4 of 16 (permalink) Old 12-10-2011, 03:14 PM
Can't tell from your avatar. Do you have the steel wheel with simulators or the alcoas?
Brett
2013 F250--4" Pure Performance Lift
2013 F150--Ecoboost
rustyshakelford is offline
post #5 of 16 (permalink) Old 12-10-2011, 07:36 PM Thread Starter
Brett
I have the Alcoas
post #6 of 16 (permalink) Old 12-10-2011, 07:39 PM Thread Starter
Originally Posted by whitenite View Post
So the chart is saying any way pictured below is fine?
post #7 of 16 (permalink) Old 12-10-2011, 10:15 PM
whitenite's Avatar
The 2 diagrams on the right pertain to tires with irregular tire wear, and how to rotate if you have this condition. The 2 on the left are for general dually rotation schedules.
post #8 of 16 (permalink) Old 12-11-2011, 09:09 PM Thread Starter
Oh ok thanks bud. I dont have any irregular tire wear as of right now. One i hit the 7500 mile marker ill rotate them. My oil change indicator came on at 5600 miles so I had to change it before the 7500 marker but decided to wait to do the tire rotation and lube the front drive shaft fitting until i hit the 7500 mile marker.
post #9 of 16 (permalink) Old 12-11-2011, 09:15 PM Thread Starter
Oh also would you happen to know if one of the two on the bottom left has any preferences/benefits over one of the other? I guess it would just be up to the owner huh. Seems like the one on the bottom to the very left would be more expensive than the other on the bottom left since it would require you to break down the tires and put them back on rim to rotate them.
Do you know where to get the best valve extenders from for the rear tires?
post #10 of 16 (permalink) Old 12-12-2011, 07:27 PM
I don't know how to do links but the company is out of southern California and is called "Dually Valves". They do not extend your present valves but bolt directly to the wheel. I have used them in several of my duallies. Good product but they are not cheap and the tire/wheel must be broken down. I have not found it necessary to rotate tires on my dually trucks.
2011 SLT BIGHORN CCLB DUALLY USED TO HAUL 4000 LB BIGFOOT TRUCK CAMPER
Chuckclark is offline
post #11 of 16 (permalink) Old 12-12-2011, 08:30 PM
Delmar's Avatar
Let me google that for you
Post up the link, this sounds interesting.
2011 3500 C/C DRW 6X6 G56 All of the EPA stuff fell off Tuned by H&S Valair Dual Disc Organic Clutch
Delmar is offline
post #12 of 16 (permalink) Old 12-14-2011, 09:14 AM Thread Starter
oh ok ill look them up and see. So their valves just replace the OEM ones and are longer? Are they stainless steel or plastic?
Do you think you'd get more miles on a set of tires if you rotated them? or no?
