Max tow package? - Dodge Cummins Diesel Forum
2010-2012 General Discussion General Chit Chat About the 6.7L 4th generation Cummins - NO ADVERTISING
post #1 of 13 (permalink) Old 11-17-2010, 11:50 PM Thread Starter
Max tow package?
Dose anyone out with a 2010 or a 2011 have the max tow package that increases your GCWR of 24500lbs to 25400lbs.What dose the package consits of??? Thanks in advance.
2011 3500 Lone Star Crew Cab 4x2 Dually, 68RFE,4.10, Rugged Brown Pearl Coat,Light Pebble Beige Dark brown interior
retiredchuck is offline
post #2 of 13 (permalink) Old 01-20-2011, 01:48 PM
johndeerrm's Avatar
Saw this article today that mentions it as well.
Delta IV Heavy Rocket vs. 2011 Ram 3500 Heavy Duty Diesel - PickupTrucks.com News
2010 RAM 2500 Laramie Crew 4x4 with the C option.
johndeerrm is offline
The Following User Says Thank You to johndeerrm For This Useful Post:
UNDER-PRESSURE (01-25-2011)
post #3 of 13 (permalink) Old 01-20-2011, 11:41 PM Thread Starter
johndeerrm,thanks for the info. That tells me that the option is not out yet.
post #4 of 13 (permalink) Old 08-13-2011, 09:00 AM
gone camping's Avatar
I've seen it available on the 2012 models with 800 Ft. lbs.
2014 6.7L Aisin six spd auto 4.10 4x4 Crew Cab Dually
gone camping is offline
post #5 of 13 (permalink) Old 08-13-2011, 01:28 PM
jhungerford12's Avatar
i thought the MAX TOW was only 2012 reg cab duallys.
2010 3500 CCLB DRW BLK/BLK LARAMIE G56 3.73 SOUTHBEND 3600DD,Black MAXX, Fass 220, Passenger intake horn, II bag of parts, ARP425s, GDP ProGate,5" TBE,FC-II's 35x12.5's 2" spacers
jhungerford12 is offline
post #6 of 13 (permalink) Old 08-13-2011, 01:37 PM
Ordered my 2012 CC dually with the max tow option.
MAX TOW PKG -inc: 4.10 rear axle ratio, dual trans oil cooler (REQ: DG7 Auto Trans) Code:AHQ $506.00 $595.00
Linetrash55 is offline
post #7 of 13 (permalink) Old 08-14-2011, 01:30 AM
Banned
Takes the GCWR to 30k lbs.
randomid25 is offline
post #8 of 13 (permalink) Old 08-23-2011, 12:13 PM
hotwheels11's Avatar
Linetrash55, can you tell me what the GVWR is on your 2012 CC dually? Thanks.
2012 bright silver RAM Laramie 3500 Dually, Crew Cab, Long Bed, 4x4, 3.73 axle, Firestone Ride Rite Air Bags, Stable Loads
hotwheels11 is offline
post #9 of 13 (permalink) Old 08-23-2011, 08:06 PM
NC Hauler's Avatar
Unless I misunderstood, the GVW has only gone up 300#, from a GVWR of 12,200#( like mine), to 12,500#....at least that was my understanding. The GCWR went all the way to 30,000#, but GVWR only went up 300#...doesn't make a lot of sense....
2016 Ram 3500DRW/CC/LB/4X4/4:10/Aisin/Longhorn/rear air assist, Peal White
2016 Jayco 4112 flood totaled..looking for another one
USAF Viet Nam Vet
NC Hauler is offline
post #10 of 13 (permalink) Old 08-24-2011, 01:13 AM
Thanks NC Hauler. I was hoping for at least 13,000 to match the Chevy. Just like you say, it doesn't make a lot of sense that the GCWR went up so much, but not the GVWR.
post #11 of 13 (permalink) Old 08-24-2011, 01:11 PM
Banned
Its because they wanted more towing capacity. Apparently they didn't care that the payload capacity is still at the bottom of the heap. Also, AFAIK they didn't increase the size of the wheel bearings or increase spring rate in the rear end so it makes sense to me that what they did didn't effect payload.
post #12 of 13 (permalink) Old 08-24-2011, 02:26 PM
Maybe someone can clarify, the new HO with Max Tow is supposed to have a 30,000lb GCWR (on select models). On the Hurt Locker Test, they had a 2011.5 3500 CC DRW HO Max Tow with a GCWR of only 29,000 (if you read the side by side comparison on first page). So is the 30K GCW only on the regular cab DRW? Can you not get the 30K GCW on the CC DRW? And if not I guess you lose the extra 1,000lbs in the extra weight of CC. Sure wish you could get the Max Tow on the Mega Cab DRW, but when I called Chrysler they said it's not available on Mega Cab.
timbuktu is offline
