Key stuck in ignition - Dodge Cummins Diesel Forum
2010-2012 General Discussion General Chit Chat About the 6.7L 4th generation Cummins - NO ADVERTISING
 1Likes
post #1 of 16 (permalink) Old 04-12-2017, 02:39 AM Thread Starter
Cashwood's Avatar
2012 Ram 3500 G56 trans.
Started the truck, ran for maybe 7 seconds and shut off. H&S was beeping the whole time the truck was running. After the truck shut off, key is now stuck in ignition. Battery voltage is good. Connected jumper cables and no dice. Disconnected the batteries for a few hours and nothing. Any ideas? Truck is completely dead, no dash lights, chimes, or anything.
Cashwood is offline
post #2 of 16 (permalink) Old 04-12-2017, 02:44 AM
2012Ram6.7's Avatar
What is your battery voltage . These trucks are very finicky on voltage.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2012Ram6.7 is offline
post #3 of 16 (permalink) Old 04-12-2017, 02:53 AM Thread Starter
Cashwood's Avatar
12.7 and 12.8. At that voltage seems like I would get dash lights, or hear fuel pump. Truck is totally dead
Cashwood is offline
post #4 of 16 (permalink) Old 04-12-2017, 03:02 AM
2012Ram6.7's Avatar
Do you have a battery charger you can put on the truck?
post #5 of 16 (permalink) Old 04-12-2017, 03:02 AM
2012Ram6.7's Avatar
That voltage sounds good, but was that with the key on?
woolfy1341 likes this.
post #6 of 16 (permalink) Old 04-12-2017, 03:04 AM
2012Ram6.7's Avatar
Just read your post again, sorry you said you had jumper cables on the truck. Did you check for any blown fuses? Could possibly be a short causing this.
post #7 of 16 (permalink) Old 04-12-2017, 03:06 AM Thread Starter
Cashwood's Avatar
Haven't pulled out all the fuses yet but there is a buzzing/humming noise coming from the fuse box
Cashwood is offline
post #8 of 16 (permalink) Old 04-12-2017, 03:07 AM
2012Ram6.7's Avatar
That would probably be a relay making that noise.
post #9 of 16 (permalink) Old 04-12-2017, 03:12 AM Thread Starter
Cashwood's Avatar
Could a relay be causing this problem?
Cashwood is offline
post #10 of 16 (permalink) Old 04-12-2017, 03:13 AM
2012Ram6.7's Avatar
Check for blown fuses, then the next step would be what caused the fuse to blow if there is one. Could it be your H&S was the culprit?
post #11 of 16 (permalink) Old 04-12-2017, 03:14 AM
2012Ram6.7's Avatar
Yes, a relay could be the cause, but relays are pretty rock solid. They usually fail due to a short or being overloaded, but not always.
post #12 of 16 (permalink) Old 04-12-2017, 03:15 AM Thread Starter
Cashwood's Avatar
I'm going to go through the fuses in the morning. I will keep you updated. Thanks for the help.
Cashwood is offline
