Where can I find a Turbo Boost hose? - Dodge Cummins Diesel Forum
2003/2004 General Discussion General Discussion for the Early (2003/2004) Common Rail No Advertising ...NO ADVERTISING
post #1 of 15 (permalink) Old 11-06-2013, 06:04 PM Thread Starter
I finally made a boost leak tester and found a leak in the first hose after the turbo. It rubbed on the intake and over time developed a leak. I think this is called the turbo boost hose. Where can I find a turbo boost hose for a 2004.0 truck with the manual transmission?
Homemade Boost Leak tester
Leak found!
2004.0 Dodge Ram 2500,Stock 5.9L Diesel H.O. 305HP/555lb.ft ,6-speed NV5600,South Bend Dual Disk clutch,2WD,2" front level, Frantz oil bypass,Cat 1R-0479 fuel filter,Baldwin BF1212 filter,Smarty S06,revo tune,Issopro FP,ETG,Boost gauges,boost elbow set to 32PSI
Jbremount is offline
post #2 of 15 (permalink) Old 11-06-2013, 07:36 PM
96 cummins is offline
post #3 of 15 (permalink) Old 11-07-2013, 08:29 AM Thread Starter
Anyone know what size diameter hose that is?
post #4 of 15 (permalink) Old 11-07-2013, 09:39 AM
MOLON LABE
8secondride's Avatar
got a set of calipers?
INFO:
DOB 09/04/02, 2500 QCLB SLT, 4x4, 47RE w/ 4:10s, WHITE|SPORT
MY ILLNESS:
ARP rod bolts, A1 studs, Haisley fire ringed, Hamilton 188/220, ii 100's, AD150, Smarty S06 PoD, HX52 w/ a custom PVC intake lol,
Hellmann sump, driveshaftspecialist 1480 1-pc DS, 5" RC w/6" rear blocks, 3" body, blacked out,
10k 55w heads/fogs, stainless 8" miters, LED everything, debadged
8secondride is offline
post #5 of 15 (permalink) Old 11-07-2013, 10:20 AM
D45
D45's Avatar
iTrader Score: 16 reviews
3" iirc.....
04 QC/LB, 4WD, 305/555 HO CTD, 6" Lift, 37x13.50 Toyo Open Country MT on 20x10 BMF SOTA 8, MBRP 5", GDP Power-Flo, GDP Air Boss, GDP Grid Delete, IceBox Intake, Air Dog 150, ATS Pulse Flow Manifold, BD Special, SMARTY SR POD, ARP Head Studs, T&C WILD Fuel Rail, T&C CPRV, II Dragon Fire 85% CP3, II 100HP Nozzles, Edge CTS Monitor, Built 48RE Trans
D45 is offline
post #6 of 15 (permalink) Old 11-07-2013, 10:37 AM Thread Starter
I trying to buy a new hose before I start taking the old hose off. The hose on the truck now is old and soft. It may tear even worse, causing down time.
post #7 of 15 (permalink) Old 11-07-2013, 11:01 AM Thread Starter
Originally Posted by D45 View Post
3" iirc.....
So, far, everywhere I find the hose online,.... it's 2.75 ID.
post #8 of 15 (permalink) Old 11-07-2013, 02:40 PM
MOLON LABE
that would make sense. 2.75 ID with 1/8" thick hose on each side = 3" hose.
INFO:
MY ILLNESS:
post #9 of 15 (permalink) Old 11-07-2013, 02:48 PM
this is the one you need. mine developed a hole as well.
DPP Turbo to Intercooler Hose 03-09 5.9L/6.7L Dodge Cummins
2004 QCSB, Smarty S-06, 4in turbo back, AFE stage 2. Dialed motorsports coils, carli bilstein 7100 shocks. Airdog 100, BMK-21 Amsoil bypass filter. 14 micron Donaldson Coolant filter. Debadged, almost De-chromed. Isspro Ev2 (Boost, Pyro, Fuel, Rail, Oil). 6K HID's
drunkenfly87 is offline
post #10 of 15 (permalink) Old 11-07-2013, 03:05 PM
fehler18's Avatar
If you get what size it is I went to a local truck and trailer shop and got a new silicone one with spring clamps. Silicone will hold up a lot better.
03 2500 qcb auto ranch hand bumper, smarty, straight pipe, amsoil 4090, autometer phantom II's
fehler18 is offline
post #11 of 15 (permalink) Old 11-07-2013, 05:10 PM Thread Starter
That's the one I need. I did not want to pay $19.xx plus $10.xx shipping and find out another hose was bad, so I went ahead and ordered the set to replace all 4 of the boost hoses. Shipping was almost the same. Their price appears to be very reasonably for the 4 hoses. There is also a 5% discount for Cummins forum members.
http://www.dieselpowerproducts.com/p...e-cummins.aspx
post #12 of 15 (permalink) Old 11-08-2013, 12:50 AM
C Schomer's Avatar
That looks like the hose on my 03 and I think it's smaller on the turbo end than the other end. So, 2.75 x 3 might be possible. Hope your new hose works! I had to find a true 3" hose for my PS turbo. Craig
03, QC, dually, HO, 6spd, 4.10, custom hauler bed, 4" turbo back, TST PMCR, PS 62/65/14, 2pc. exh manifold, Walbro 391, 2, PRXB, Rancho 9000s, FS airbags, Onboard air. 08 Sunnybrook 30 RKFS
C Schomer is offline
