What is this item? - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-07 Common Rail Forums > 2003/2004 General Discussion
2003/2004 General Discussion General Discussion for the Early (2003/2004) Common Rail No Advertising ...NO ADVERTISING
Old 04-20-2012, 01:59 PM   #1 (permalink)
dodge man2's Avatar
What is this item?
I tried to get a picture of it, but its tucked back in an area that won't show up. I first thought it was my lift pump, but after looking at the service manual, I'm pretty sure my lift pump had been moved to the tank. There is nothing attached to the back of my fuel filter bowl, and there is written on the radiator support that the lift pump was replaced at 75,000 miles.
The item in question sits farther back and closer to the engine than the fuel filter bowl. Its kind of long and skinny(runs up and down), black in color, and has what looks like cooling fins, almost like heat sinks. Its on the drivers side of the engine, towards the back. It seems like I've read of some kind of heat exchanger for the transmission? Is that what this is?
2004, 3/4 ton, Quad Cab 4x4
dodge man2 is offline   Reply With Quote
Old 04-20-2012, 03:10 PM   #2 (permalink)
BZ2500's Avatar
Yes, it is the heat exchanger for the transmission..
03 2500 4x4 Laramie: Garmon, Smarty, Edge, CFM, S&B, Thuren 3", King 2.5, Eagle, 315 Yokos, custom front and rear bumpers....
BZ2500 is offline   Reply With Quote
Old 05-07-2012, 04:35 AM   #3 (permalink)
Snake Oil Manufacturer
3lakesguy's Avatar
Watch that puppy. When you tube off turbo your trans fluid pressure goes to zip, but since the coolant is hot it stays at pressure. Factor in a few hundred thousand on the clock and the coolant will push through the separator, and you'll have coolant in the tranny and oil in your coolant. If you're luck it will kill the electronics in your tranny before it completely destroys it, when they happens, drop the pan asap. But if your not lucky, goodbye transmission and you'll have to flush cooling system and probably replace all you hoses since oil will make them go bad.
Mine did this . Decided not to buy a new one ($1200 at stealership), instead just bypassed with standard hose for coolant and had a hydraulic line with pressure fittings for the tranny. Have't had any over heating issue with the TC.
'03 toolwagon. ummins Powered Motor home for sale --> TX: Cummins 40' 2001 Allegro Bus 46k Miles
Lifetime SCI and NRA member
"Exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster"-Jeremy Clarkson
BEFORE posting, please click here
3lakesguy is offline   Reply With Quote
