Hemi to cummins swap - Dodge Cummins Diesel Forum
2003/2004 General Discussion General Discussion for the Early (2003/2004) Common Rail No Advertising ...NO ADVERTISING
post #1 of 12 (permalink) Old 03-20-2011, 08:28 PM Thread Starter
So ive been toying with the idea for some time now since I love everything about my truck except that its not a diesel. Ive done a little research and it can be done but as long as its a similar truck to avoid the most headaches. I am really thinking about it now since I found this truck locally and its pretty much exactly identical as mine except for the engine.
2003 Dodge Ram
So my questions are how hard would the swap be if I got this truck and is the price they are asking a good price for a truck in that condition?
Thanks for any input
03 2500 4x4 HEMI laramie auto 4.10s at3030 w/ 5" tip,K&N cai, hypertech programmer, tmr, Kore HP kit, 35" Hankook MTs
superfordman is offline
post #2 of 12 (permalink) Old 03-24-2011, 10:08 PM
butcher247's Avatar
it would be way easier to sell your truck and buy a cummins. i dont think i have ever found anyone who has swapped a hemi or 4.7 from a 1500 to a cummins in a 1500. it would be sweet dont get me wrong but it would be basically pulling a whole 2500 cummins front end and welding it onto a 1500 hemi/4.7 front end along with swapping all the modules, all the wiring and all the linkages. hope this helps and anyone else that comments back feel free to correct me.
91 D250 Work in progress.
94 2500 Work in progress.
07 JGC SRT8 To go fast.
butcher247 is offline
post #3 of 12 (permalink) Old 03-24-2011, 10:11 PM
It sounds to me like it wouldn't be very cost effective. IMHO
carl74sd is offline
post #4 of 12 (permalink) Old 03-24-2011, 11:35 PM Thread Starter
butcher, first of all my truck is a 2500 hemi look at my sig lol, so it wouldnt been near that difficult but i guess not as cool as a cummins in a half ton 3rd gen either haha
carl, ya thats what i was thinking to that alot for what i get but then ive also put around 3k into my truck this past year with tires and parts so kinda dont want to get rid it of either. my plan would be to since the doner truck isnt that bad swap the hemi back into it if i could and make it a f*ck around with 4x4 pretty much. would be ALOT of work for both trucks but since there both complete and the exact same truck pretty much should just be mostly wrench time
post #5 of 12 (permalink) Old 03-25-2011, 12:09 AM
slickrock steve's Avatar
Hmmmm...I wonder if the front springs and suspension/spindles is different cause of the heavier engine? You might be switching whole front ends as well.
05, cclb ,srw, looong bed, 2 wd, 48re, Isspro gauges, stocker for towing my horse trailers
slickrock steve is offline
post #6 of 12 (permalink) Old 03-25-2011, 01:46 AM Thread Starter
the springs are different for a cummins and a hemi but thats it, about everything else on the trucks is the same
post #7 of 12 (permalink) Old 04-02-2011, 03:50 AM
No way, no how, would'nt do it. In my former life as an automotive mechanic, I performed engine swaps, and even with detailed planning there were always surprises that complicated the project and increased the cost. These were also much simpler gas for gas swaps. Two small examples: Does your gauge cluster even have the indicator light for the glow plugs and if it is the same cluster as diesel, is all the wiring there for it? Think of all the changes that will be necessary to the fuel delivery system alone. If your not bothered by the enormity of the project, more power to you! But I think "Butcher247" is right, you'd be money ahead to just look for replacement with a Cummins.
2004 2500 QC, 305/555, NV5600, Hypertech Max Energy, Diprocol Pyro, Hell Bent Steel 2" leveling.
whtfarmer is offline
post #8 of 12 (permalink) Old 04-02-2011, 04:05 AM
hellsace07's Avatar
cummins dont have glow plugs last time i check i may be wrong on that i thought they had a heating pad or something along those lines...
hellsace07 is offline
post #9 of 12 (permalink) Old 04-02-2011, 04:20 AM
they have a grid heater,
i like to refer to it as a waffle iron
04 quad cab, long box, 4x4, 5spd, south bend clutch, upgraded main shaft, egde box, diablo predator, fass fuel system, afe intake 4" straight pipe, pyro and boost gauges, pac brake, 5" pro comp lift, 37" toyos.
25jon25 is offline
post #10 of 12 (permalink) Old 04-02-2011, 04:27 AM
hellsace07's Avatar
ya thats what i thought the other guy that they had glow plugs but i think superford man should do the swap you will be very happy with the out come just some time and wrenching and a few mods
post #11 of 12 (permalink) Old 04-02-2011, 02:01 PM
WHat about 4bt? that would be plenty for a 1500
25jon25 is offline
post #12 of 12 (permalink) Old 04-03-2011, 02:00 PM
Sorry, my mistake, I guess I spent to much time dealing with those worthless glow plugs. Heat plate, heat plate, heat plate. Thank you Cummins for the heat plate.
