What size tires for better MPG @ 70-75 MPH? - Dodge Cummins Diesel Forum
1st Gen Tire and Wheel Discussion of tire and wheel options
post #1 of 16 (permalink) Old 12-26-2016, 03:52 PM Thread Starter
I have a '90 non-I/C stock (as best as I know) G360 5-Sp and 4.10 gears.
I need tires and am wondering if I should go for 265/75-16 or taller but wider 285/75?
I wonder if lowering then engine's RPMs with the 285/75s will be offset by their rolling resistance?
I will be getting a somewhat agressive tire as I sometimes find myself on slick muddy roads.
I am also going to be getting cheap tires (low budged and old truck), so something like a Kenda Klever MT or Ironman All Country.
So, back to the question...... 285 or 265?
I know I would do better with a 255/85, but they are hard to find and out of my price range.
I'm hoping to get a set of 4 for about $600.
What are your suggestions? Thanks.
zoomer is offline
post #2 of 16 (permalink) Old 12-26-2016, 04:04 PM
Moderator
9297oldram's Avatar
You get better MPG's with a narrower tire.
92 D250 parted out
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 4x4 with 92 Cummins zf5
9297oldram is online now
post #3 of 16 (permalink) Old 12-26-2016, 05:03 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 12 reviews
Hard to get good mpg with a 4.10 truck. Unfortunately, mine didn't change from 235/85 to 255/85 or anything else I did to it for that matter. I would at least go with the 285/75
2012 Laramie Longhorn, EFI by Ryan, 5" FloPro, 35x12.5x20 Toyo AT II
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, Old Numbers 421/946
1998 P-Pumped 24v, 4x4, NV4500 swap, Valair Dual Disk, BHAF, 4k GSK, .024 Dv's, Fass 150HPFP, Isspro, 5" exhaust, 2" Thuren Coils, Overland Shocks, 305/70r17 Nitto TG, 4th Gen Wheels, Fat Bald Asian 7x.010 Thanks Lee! VP Numbers 359/744
2005 Dually, 285/75r17 Nitto TG, Redhead, Thuren, Edge CTS, Smarty S06
98whitelightnin is online now
post #4 of 16 (permalink) Old 12-26-2016, 05:40 PM
1320Fastback's Avatar
I'd go with the 285/75R16, at the speeds were capable of with 4.10s I don't thunk running a narrower smaller tire is going to be worth it vs getting further per revolution.
If you tow make sure the tires are Load range D or E.
92 extended cab long bed D250, Getrag 5 Speed, 4" Straight Piped, 366 Spring, DAP 5x12s, AC, Air bags, 3.54 ratio, 220k miles.
1320Fastback is online now
post #5 of 16 (permalink) Old 12-26-2016, 06:24 PM Thread Starter
1320Fastback, I tend to go for load range E due to stronger sidewalls (thorns etc.). I won't be towing anything heavier than a trailer with 2 ATVs.
9297Oldram, I know skinnier is usually more fuel effecient, but I didn't know which trumped which (lower engine RPM from taller tires, or lower rolling resistance from skinnier tires)
Is there another COMMON tall skinny tire (taller than 235/85) that I'm not thinking of that fits a 16" rim?
If there really isn't anything else out there, then 285/75 will probably be the choice, and I'll just live with a higher RPM on the highway (I guess I could slow down.......nahhh)
zoomer is offline
post #6 of 16 (permalink) Old 12-26-2016, 06:32 PM
Moderator
9297oldram's Avatar
I have these they really bite in the mud and snow. https://www.onlinetires.com/products...horn++bsw.html
92 D250 parted out
post #7 of 16 (permalink) Old 12-26-2016, 06:39 PM Thread Starter
9297oldram, Thanks.
They look good, but out of my price range. With shipping, they are about $750. I still have to pay 16 per tire for mounting and balancing locally I appreciate your input. Being on the poorer side of the spectrum sucks.
I may have to go for something cheap like these:
4 Kenda Klever M/T KR29 Mud Tires 285/75R16 285/75-16 75R R16 2857516 | eBay
zoomer is offline
post #8 of 16 (permalink) Old 12-26-2016, 06:52 PM
Moderator
9297oldram's Avatar
Originally Posted by zoomer View Post
9297oldram, Thanks.
I dismount and mount my own tires and usually don't worry about balancing unless they are really bad. Big tires like that are easy to put on the rims, and I used to take them to Walmart and they would dismount for $5.00 each.
92 D250 parted out
post #9 of 16 (permalink) Old 12-29-2016, 10:07 AM
9297oldram, Thanks.
Have you checked out Tire Rack? they have some really good prices.
My build thread over here.
mknittle is offline
post #10 of 16 (permalink) Old 12-29-2016, 10:46 AM
dwengi's Avatar
I just bought these from Tire Rack: LT265/75R-16 SUMITOMO ENCOUNTER HT E - around $115 each. Not particularly aggressive tread.
I can confirm these fit on a '93 4x4 with no rubbing whatsoever.
dwengi is offline
post #11 of 16 (permalink) Old 12-29-2016, 11:48 AM Thread Starter
I currently have 265/75-16 and want to go taller.
Thanks for the Tirerack suggestion.... I'll check them out.
I really need a more agressive tire than that for the dirt/mud roads I travel.
I also live 80 miles from the nearest place that Tirerack works with...
They want $40.53 shipping PER TIRE!!! To ship them to me. That makes the cheapest tire they carry
a total of $750.12 for a set of 4 (plus local mounting even if I do it myself).
Thanks for your input everyone. I wish I could have gone for a taller skinny tire as was suggested, but they just cost too much. I appreciate your advise, but my wallet made the final decision. Wish me luck with the Kenda's, they cost $585 including shipping to my front door.
I'll see if I can take 9297oldram's suggestion and try mounting them myself to save some cash.
Thanks again for your suggestions everyone.
zoomer is offline
post #12 of 16 (permalink) Old 01-01-2017, 12:09 AM
myother4x4isaCJ7's Avatar
How many miles have you put on these? Had these on a jeep before and I burned through them way too quick I've heard they are soft rubber.
1992 w250- glasspack muff, hx35, 3200 gov, fuel screw in 1 1/2, bd fuel pin, a518.... R.I.P. 1-2-17 there will be another
myother4x4isaCJ7 is online now
