Go Back   Dodge Cummins Diesel Forum > Classified Ads > 1st Gen All Products
1st Gen All Products For Sale: All Items related to the first generation of Dodge Diesels. (1989 to 1994 Dodge Ram Diesels)
Old 11-03-2009, 07:45 PM   #1 (permalink)
RSWORDS's Avatar
Air To Water Aftercooler
Never installed, has some very light scratches, no dents. Comes with fittings for 5/8" supply and return hose (not the ones in the pic). $110 Shipped anywhere in the lower 48!
RSWORDS is offline   Reply With Quote
Old 11-04-2009, 09:36 PM   #2 (permalink)
Bobby, is that one from Frozen Boost?
riflemanusmc is offline   Reply With Quote
Old 11-05-2009, 10:32 AM   #3 (permalink)
um call me stupid but i dont quite understand how that thing works
1991 w250 non int, 2 turns on fuel screw,starwheel pegged,6inch lift on 36 inch military tires,gauges,bhaf,soon to be a 5spd
97power ram is offline   Reply With Quote
Old 11-05-2009, 01:49 PM   #4 (permalink)
resident trans breaker
jackblack99's Avatar
air flows through the 2 big openings.. the big square in the middle is like a radiator. you hook a water supply to the top and bottom of the square and when water flows through it cools the air down.
94 reg cab dually... haisley 911 pump trans is fixed, now the nonstock spinny thing broke.
jackblack99 is online now   Reply With Quote
Old 11-05-2009, 08:48 PM   #5 (permalink)
RSWORDS's Avatar
Yes I got it from frozen boost
Old 11-05-2009, 08:49 PM   #6 (permalink)
RSWORDS's Avatar
Water To Air
Old 11-05-2009, 10:26 PM   #7 (permalink)
1ST GEN MODERATOR
Philip's Avatar
I did some cleanup for you RS.
Old 11-06-2009, 02:35 AM   #8 (permalink)
so basically a intercooler but just doesnt cool as much im guessing
Old 11-06-2009, 09:40 AM   #9 (permalink)
RSWORDS's Avatar
Thank You
thats debatable, KTA made 627 with an Air To Water, not this style but the factory cummins one. The biggest plus is you can run ice water through it and get you intake temos down close to freezing. While melting piles of ice day to day is not cheap, its nice to use oulling or drag racing. and if you put a heat exchanger in the return line with a little fan you can keep the water around ambient temps, same with your intake air temp.
Old 11-08-2009, 11:25 AM   #10 (permalink)
RSWORDS's Avatar
Bump, All boxed up ready to ship...
Old 11-12-2009, 05:36 AM   #11 (permalink)
How does it hook up to the truck? Do you have to get different tubes from some where to adapt?
92' 4x4 D250 s.cab 5pd. custom 4-5in exhuast. pump 1/2 turn from run away. hx35. k&n filter. lookin for more
kingspade108 is offline   Reply With Quote
Old 11-13-2009, 03:55 PM   #12 (permalink)
RSWORDS's Avatar
It would have to be a custom set-up...
$100 shipped.
HTML code is On
