Go Back   Dodge Cummins Diesel Forum > Classified Ads > 1st Gen All Products
1st Gen All Products For Sale: All Items related to the first generation of Dodge Diesels. (1989 to 1994 Dodge Ram Diesels)
Old 10-25-2009, 12:34 AM   #13 (permalink)
bad421's Avatar
whats the difference? Just longer studs right? How much do you want for one? I just changed wheels on mine and used the long nuts, This will be for a friend of mine with a W250. Thanks
91' W350 5spd, D60/D80 4.10s, 6" stack, HX35, 2nd gen I/C, pump almost maxed and bumped, stock non I/C injectors, autometer guages. 256hp/565ftlbs Weak. going p-pump.
bad421 is offline   Reply With Quote
Old 10-25-2009, 01:20 AM   #14 (permalink)
They have the same studs as yours did originally.
I can help you on it.
If you want the hub only, it's $50, plus shipping, with a good drum is $85, plus shipping.
Mark.
Mark Nixon is offline   Reply With Quote
Old 10-29-2009, 11:11 AM   #15 (permalink)
Still available.
Once the final little nit picky stuff on the carhauler is done, it will all be gone for scrap.
Texas truck, clean metal, would have repaired, but frame is bad.
Need funds and scrapping a few things will generate them, if nothing else does.
Mark.
Old 10-31-2009, 01:23 AM   #16 (permalink)
bad421's Avatar
is it a dana 70 or a 80? also the inner bearing is bigger than the outer right? could you measure the inner hub seal for me? my buddy's is 3 7/8". Thanks James
Old 10-31-2009, 01:45 AM   #17 (permalink)
You're going to MAKE me pull one, aren't you?
I need to know if his axle shafts are STUDDED to the hub, or BOLTED to the hub.
Studded has NUTS to hold on the axle and, well, I'd hope that you know what bolted on looks like.
Mine are all DANA 70s.
Mark.
Old 10-31-2009, 02:08 AM   #18 (permalink)
bad421's Avatar
Ok his hub has the studded axleshafts. Thanks James
Old 10-31-2009, 02:18 AM   #19 (permalink)
Will know to-morrow.
Mark.
Old 11-03-2009, 02:30 AM   #20 (permalink)
bad421's Avatar
did you find out anything? thanks
Old 11-03-2009, 10:38 AM   #21 (permalink)
Yes, it's same.
It was a PITA getting the drum/hub off that, misplaced my nut tool and used the "chisel" method to remove it.
Mark.
Old 11-04-2009, 01:15 PM   #22 (permalink)
Cummins Shakes It
crazytexas86's Avatar
do you have the radio and door speakers? if so will they fit an '89 and how much?
'89 single cab dually. TBE
GONE BUT NOT FORGOTTEN :: 2005 4x4 long box SLT, G56, banks ram air, what silencer ring??lol CFM+ intake manifold, 4" turboback with 6" stacks, bully dog tripple dog GT.
crazytexas86 is offline   Reply With Quote
Old 11-04-2009, 09:10 PM   #23 (permalink)
All I have for a working radio is a cassette one. Or a CD one, which also will work.
Not sure if the speakers are good in this truck or not.
Mark.
Old 11-05-2009, 02:30 PM   #24 (permalink)
deanhinsley1963's Avatar
do you have the big truck mirrors that were on the cab/chassis by chance?
92 D-350 Dually,Reg. cab C.T.D. Auto,3.54 limited slip,gauges,BHAF,3turns on smoke screw,2 turns on fuel screw,fuel pin indexed,denny-t pin and 366 spring next!!!!
deanhinsley1963 is offline   Reply With Quote
HTML code is On
