Pacbrake has a solinoid for this set up, but in my estimation its expensive.
I went cheap!!!! Went to a pet store bought a gang valve/on and off like a ball valve for the air lines and run two small tubes in to the cab, attached them to vaccuum source on the firewall and run them into the cab and attach them to the barbs and walla, two low. Turn off the vacuum before you shift the transfer case. Be carefull you are working with TWICE the torque as normal in this operation.
Draw back is there is no light activation, and you must turn the vaccuum back on when done. Works fine on mine. had it for a couple years.
nivram
