Originally Posted by Mopar1973Man
For the OP how many miles on the brake before replacement???
Surely you have a tough time catching me... 150K miles and still running on factory brake pads!
I might change brake pads by 200K miles...
Exhaust brakes are really handy!
Odometer - 118K when I did the brake job, the fronts were overdue for a brake job by about 2K as they started squealing like a pig. I continued to drive since I knew I was replacing the rotors anyways. The rears still have lots of pad left. The truck had 315/75 rubber when I got it at 56K and I swapped the mud tires for 315/75R17 BFG AT on H2s. So, it the odometer is about 9% off I believe since about 50K. Based on the tread left on the tires when I bought it I would guess it had the larger tires on since about 50K, so equivalent to 125K or so on 1 set of pads. Not bad! I do not have an exhaust brake like you, but I am easy on my truck.
2001.5 2500 4x4, QC, 6 spd, 57/65/12, Int heater delete & horn, 5" exh, AD 150, Psychotty intake, 275 Inj, Edge Comp, Vulcan DS w/ dual return, SB Con OFE, 2" front level kit, 315/70R17 BFG A/T on H2 wheels, 3rd gen front brakes, DSS, Custom stereo.
