Old 07-07-2009, 06:26 PM   #5 (permalink)
unixcowboy
unixcowboy's Avatar
Some of us in the north do the same thing....
Mine's MIA...
Made it through last winter with no problems..Truck turns over 3 cylinders instead of 2 before starting.
'93 D250 CC HX-40 60/65/17 w/hx50 flange - hit 57 held 55 psi OOPS => 6x16's <=, 366 spring w/1 turn clipped, power screw bottomed-backed off 1/2 turn, Ol Smokey's power pin(modified), removed limit washer, smoke screw fully out, starwheel 4 up - modified top to get pin higher, '94 built trans - clutches and some hard parts, trans cooler in front of radiator, 4510 w/4 1/2" intake and heat shield, htr grids MIA, 4" dp -> 5" pipe -> 5" Stack, 285's rear 265's front
unixcowboy is offline   Reply With Quote
