Old 07-05-2009, 05:15 PM   #11 (permalink)
dpuckett
I had a tie rod end go bad in my W350. I replaced it, and turns out I didnt get the TRE in as far as the other one. My wheel was off center, but it wandered like a drunk sailor on shore leave, too. I measured the toe, and it was actually toed OUT about 1/4". I adjusted the toe so it was toeing in about 1/16", and it now tracks straight and true.
Mark the center of your tires, and get a helper to measure the distance between the centers. The front should be closer than the rear (toeing IN). I dont know how much difference there should be, I just took a reasonable guess on mine and will do the math, converting degrees to inches someday.
I would check everything under the truck and look for bent stuff. These trucks are tough, but not quite bullet proof.
Daniel
92 W350 xcab LE, 5spd, 3.54s pump tweaks, piston lift pump, 60mm/ 16cm turbo. plain tailpipe with muffler. For sale
dpuckett is offline   Reply With Quote
