When you kill a hot motor it warms up 40+ more degrees than running temp. I would fix valve cover leak and wash again problem should go away.
2003 quad cab powered by 91 12 valve ve44 pump with 62 CC head fuel pin 80+ injectors 3 inch turbo with a 48RE automatic. Set up to run on strait waste grease, Biodiesel or NO2
http://community.webshots.com/user/bridelessd7
