Originally Posted by edcasey
I just want to clear up a few things about hybrid Dana 80 axles. All Dana 80 axles used in second generation Dodges (diesels and v-10's) are hybrids including the 3500's. They uses a Dana 80 carrier and a 1.5 inch 35 spline axle shaft. The Dana 70U that is used in 2500 automatics only has a 32 spline axle. The only differences from the Dana 80 hybrid used on some 2500's(manual transmissions and camper packages) and the Dana 80 hybrid used on 3500's are the outer wheel spindle, hub and brake assemblies to accommodate the duallies.
I'm not sure why there has been so much misinformation about 2nd gen axles.
It was 98 that I saw the outer wheel spindle that looked exactly like the 3500's. I assumed the 3500's were full D-80's and so was the odd ball 2500's that had the same spindles. I wondered why the D70 and D80 could hold the same lunch box lockers. So the axle shafts are actually D-70 axles, but 35 spline.
