Thread: modded VGT's
Old 07-02-2009, 10:11 PM   #46 (permalink)
CW6.7
CW6.7's Avatar
Originally Posted by Rockwerx View Post
This new turbo sounds like an improvement over the stock design. Does the Fleece 66 turbo have the "silencer ring" on it? Does it make a lot more noise than the stock VGT? How much hp is it designed to support?
It is an improvement over stock. The Fleece66 does keep the "silencer ring" because its more of an entire bushing then just a ring. It's hard to say hp support but probably 600. It's the torque thats killer. 600hp could easily be 14-15 even 1600ft-lbs. If we could ever keep a trans together we could have a better idea.
Originally Posted by MEZ View Post
so yall are just taking stock turbos and milling them out basically to a 66mm and putting new turbines in them?
Yes and No..... the idea is to pack as big of a punch as possible into a "stock" appearing turbo. From the outside they are stock but yes the insides are all replaced, milled, and exchanged for bigger and better parts.
07.5 - QCSB - 6.7L - Smarty - Suncoast 44-3D 68RFE - Afe intake - TS MP8 - 5in Magnaflow TBE - Blocked EGR - 22's - Bilstien 5100s - Fox Stabilizer - Optix (Boost, Drive, Trans, Pyro, RP) - Pioneer D3 - Fleece Boost Controler
CW6.7 is offline   Reply With Quote
