Do NOT use a TORCH!! spring steel will collapse if you heat it up as you will mess with the temper heating it up.
You can install 1/2 ton springs
Im going to run 3/4 ton gasser springs to drop 1" or so then make new blocks to match the front drop so its level or 1" above the front
IAN COLEMAN - President Great Lakes CUMMINS Crew
1990 W350 4x4 LE std cab auto
Project Restoration
2001 2500 4x4 3rd gen head, Twin Turbo, DTT trans, Monster pump
2006 2500 4x4 Smarty JR, H2's, B&W, AFE, 5" exhaust, meyer plow
