Originally Posted by DodgeLuvr
Problem with a fuel pump shut off is a thief will keep cranking thinking something is wrong and screw up your starter, with a battery disconnect they are not going anywhere.
And your ECM is relearning every time you reconnect. That used to be a good option until these days of Smart ECM's They must be kept powered up.
Tom
2008 Quad-Cab,LB, 2500, 6.7L, 4X4, White/Kaki, Big-Horn, 3.73 Auto, AS flash, K&N Air Filter, no baffle,
Testing in progress- step 4, Stealth DPF, Smarty sw3 PMT gauges. Mag-Hytec Pan & Diff covers.
Toms smarty Journal .......
DIY Deletes How-To
Stealth is the WORD!
