Originally Posted by Cummins FTW
So you wired from the relay box to your switch only?? Almost seems like if you cant find that harness better off wiring the whole thing from scratch so you can have the fogs on whenever you want?? I just don't know exactly connector would come with those lights from LMC.
I bypassed the 1st relay so I can have fogs whenever I want.
Here's how I did it.
I connected one wire from battery(+) to switch, and from switch to relay pin #2. Pin #5 on relay is always with 12V, so when I engage relay it sends that 12V to pin #3 which then goes to lamps. I cut off the connector near the bumper and made my own to connect the lamps.
Connector near bumper. Lamps are grounded to the bumper.
Relay wiring. Black wire is ground to pin #1(it doesn't have ground if 1st relay is removed), white is 12V from switch to pin #2. Pins are labeled on relay. I also heard mod about cutting the pin #2 on fog lamp relay #1 to make fogs work when high beams are on, but that didn't work for me so I had to hack my own way a little bit.
The switch that came with the lamps is too bright at night, so I think I'll change it to OEM Mopar switch soon so it could look more original.
