Probably, but I don't have those tools at my disposal. Hmmm. On the thread you linked me, (on my truck) There should be an exposed 1/8 plug.
"On the side of the intake, on the motor there will be a 1/8 in pipe plug allen head i think,just use that. No drilling or tapping.If it's an auto truck you will need to drill an over sized hole to acess this port behind the throtle bracket."
"Mat the drill the mount is for non IC truck. On the IC truck that 1/8" pipe fitting is in the clear.
Moparman look under the air intake horn on the driver side of the engine. Dead center of the air intake horn is a 1/8" pipe plug facing the fender. Use that. "
Do these sound accurate?
92Dodge W250 LE 5spd w/ NV4500 BHAF and 4" Turbo back exhaust 6" lift on 35" eggs
