On the drivers side of the engine there is a large black bracket that secures the throttle and tranny linkage. Behind this bracket there is a 1/8" NPT pipe plug in the side of the head. That is where you need to hook the line up at. I have a 1" hole in my bracket that made it easy to hook up the gauge but I cannot remember if that hole is in the bracket stock or if it was drilled for access to the plug.
I thought there was a picture in the tech section that showed the setup but I was wrong(or at least I didn't see it!)
Here is a link to some more discussion on this item (still no picture tho) You can drill and tap the air horn or use a banjo bolt at the base of the air horn as well.
boost guage hookup
Stan
93 D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust, modified tranny, EGT/boost/tranny/tach gauges, TPS removed, a little chrome under the hood. Mag-Hitec tranny and diff. covers. Rear sway bar. Line-x bed liner, after market seats. Front end rebuilt with new springs - 2 " taller now. Single stage Water/Meth system installed. Oversized intercooler w/3" IC lines.
05 Chevy 2500 HD, Duramax W/Allison, 17" Hummer wheels w/285-70-17 BFG's, modified air box, ported turbo mouthpiece. Predator programmer.
