Old 07-02-2009, 05:26 PM   #1 (permalink)
Zacharynels
Zacharynels's Avatar
Having trouble with boost plumbing.
I have a couple gauges I got for my 92 12v. Doing the electrical and plumbing for my boost and EGT today. I am having some trouble with where I should actually install and how to install the boost lines. I have searched and read and searched and read some more and still cannot come up with a solid answer.
I have a 60psi, glowshift boost gauges. Came with hose a t-fitting and psi restriction end. Now it says to run it to a vacumm line with the T-fitting... Is this even possible on this truck, if it is what line should I use and if it's not, what is the easiest most accurate reading for this. What will i need to do this install and what do I need to purchase if I have to drill.
Thank you
92Dodge W250 LE 5spd w/ NV4500 BHAF and 4" Turbo back exhaust 6" lift on 35" eggs
Zacharynels is offline   Reply With Quote
