like mathew8pt said, its going to take a 800+hp truck to crack low 11's. (i have looked into it a little)
the reason why manulas are slower, is they shift slower, and they loose boost between shifts. the best solution i found (so far) is a procharger/turbo setup. the procharger should help prevent you from loosing boost between shifts. and doing 3ed gear boosted launches should help you too.
then the problem becomes holding it together
'02 | 2WD | 2500 | NV4500
"Diesels dont run away. Diesels over speed, mechanics run away"
