Originally Posted by genestealer
I did on my 96. I found connector by the bumper and 2 fog lamp relays were in place in relay box, but I didn't find the connector behind the dash, so I did my own wiring from switch to relay box. The first relay is used for turning fogs off when you turn high beams on, I guess. But I think wiring harness in my truck was messed up and fog lamps turned off whenever I turn on my park lights, low beams or high beams. I took out the first relay and wired switch to second relay.
So you wired from the relay box to your switch only?? Almost seems like if you cant find that harness better off wiring the whole thing from scratch so you can have the fogs on whenever you want?? I just don't know exactly connector would come with those lights from LMC.
05 BLK'd Out 2500 CTD 4x4 Auto,.. Full Dipricol's 4' TBE AFE Stg.2 Intake CFM Smarty@Revo #3 398/747 @ Spring Fling '09
97 BLK 2500 CTD 4x4 5pd, 4'TBE, Pump Mods w/ 0 plate, Haisley Puller w/billet input
